Author Topic: Windshield backpressure  (Read 18293 times)
Re: Windshield backpressure
« Reply #40 on: November 11, 2011, 11:03:49 AM »
I see that Kirby is taking those blue pills, no wonder he's so stiff.    (someone had to say it)
« Reply #41 on: November 11, 2011, 09:46:04 PM »
On my '10, the dash vents that are supposed to address the back pressure don't seem to be enough. The only time I have
head buffeting is when there is a strong crosswind. So basically I have no buffeting problem, however when the windshield
(stock '10 with MRA spoiler) is all the way up it feels like someone behind me is trying to push my head forward and down, and in 20
minutes or so my neck muscles are screaming in protest. I'm going to try and make a CalSci type vent in mine and see if that helps.
« Reply #42 on: November 12, 2011, 05:50:56 AM »
Ok, I know some of you guys have 10's on up, where's the pics of the vents?  What do I have to do, call a breakfast or lunch meeting in Fredericksburg and bring my own camera?
« Reply #43 on: November 12, 2011, 06:06:38 AM »
Come on guys, Jim has a sword and he's not afraid to use it!
Offline wally_games
« Reply #44 on: November 12, 2011, 01:48:21 PM »
Make it breakfast in Utopia and I'm there!!
« Reply #45 on: November 12, 2011, 04:25:08 PM »
Per earlier comments cee bailey's is 100% aircraft quality, and the same material they use on the air force jet canopies they manufacture
Offline C1xRider
« Reply #46 on: November 12, 2011, 04:52:36 PM »
Wow, Jim is insistent, isn't he.  ::)
OK Jim, since SteveWFL is ignoring you, I'll help you out.  Ignore the dirty bike though, I got caught in one of those "surprise showers" (actual statement from the weatherman) three nights ago, and it was 36F when I rode in the next night.  It's been way to cold to clean it up since then.
« Reply #47 on: November 13, 2011, 06:55:12 AM »
You'll have to talk to your wife and/or girlfiend about that me thinks.  ;)
« Reply #48 on: November 13, 2011, 07:07:02 AM »
Thanks. I don't think it looks dirty.  What I am getting at is how hard would it be to retrofit the dash plastic to add to an 08 or 09 bike.  I take it there aren't any vents in the front of the bike under the screen?
« Reply #49 on: November 13, 2011, 08:49:29 AM »
The new vents in the fairing covers are directly behind the slots that the windshield arms travel in. As I remember, no, there are no additional intakes on the front of the bike, just the windshield slots (which are substantial).
Offline C1xRider
« Reply #50 on: November 13, 2011, 11:43:18 AM »
Yes, that is correct.  When looking into the slots vents from the back, you can see straight through, and out the windshield arm slots to the front.
« Last Edit: November 13, 2011, 05:27:45 PM by C1xRider »
Offline C1xRider
« Reply #51 on: November 13, 2011, 11:49:08 AM »
Jim,  the part with the vents in it is one piece all the way down around the new glove box.  I don't think it would be as simple as just swapping plastic.
Another idea for modding the 08/09's would be to find a small dash vent from a car, cut the existing dash, and install the vent.  Then it should look a little better than a couple of large holes.
Although, the viewing angle to see those holes is only from a low position, so really, only really short people or little kids would notice them.
« Reply #52 on: November 13, 2011, 12:53:28 PM »
That just caught my attention and I scrolled back. Apologies, I never ignore Jim or anyone intentionally.  Great pics, I usually never miss a chance for a pic op either
« Reply #53 on: November 13, 2011, 12:54:08 PM »
It would be cheaper to buy a Calsci, then.  Forgot you guys had that silly lockable box on the left side  ;) .  I could cut some vents but I would most likely wind up in the emergency room getting stitches.
« Reply #54 on: November 13, 2011, 12:54:54 PM »
I know, Steve.
Offline C1xRider
« Reply #55 on: November 13, 2011, 05:26:30 PM »
I know, Steve.
Yes, we should ALL know that by now!   ;D
« Reply #56 on: November 14, 2011, 04:27:15 AM »
Someone on the old forum did cut two 1" holes in his dash. Then he glued som black mesh on the inside of the cover to fill the hole. If I remember correct, it did help.  :-\
Offline julianm
  • Country: za
« Reply #57 on: November 14, 2011, 07:56:53 AM »
I made a mod to the standard 2010 -screen by drilling 2 holes furthur down which allowed me to move the screen up by about 2 inches. When riding and raising the screen up , I found a definite push towards the screen caused by back pressure. This was solved by cutting 2 MRA varioscreen type holes in my screen using a slow speed drill for the corners and a metal blade on a jigsaw at slow speed to cut the slots. It does result in more noise though.
Attached  is a pic. of the MRA screen
Offline jonathan
« Reply #58 on: November 14, 2011, 10:03:38 AM »
You could also just drill a series of smaller holes and not worry about the mesh.
« Reply #59 on: February 03, 2013, 12:44:43 PM »
Back pressure update
I made the cut in my stock '10 similar to the Calsci vent, and have tested it for a few months. It helps a little with the back pressure, but not enough. I debated ordering a MRA or a Calsci and yesterday I finally ordered the Calsci medium. According to the Calsci site info, it should be about 1 3/4 to 2 inches taller than my stock. If it's too tall I'll just cut it. If the new Calsci solves the problem then I'll continue to modify the stock 'shield to see if I can fix the problem with it. There seems to be considerably less material at the bottom of the Calsci, so maybe that will be the next cut on the stocker. It could be that the little flip at the top of the stock screen is what is causing the back pressure problem. If so then I guess it'll end up being cut down into a summer shorty, or perhaps become material for some home made hand wings. Time and money will tell. ::)
(Hmmm....it took me 14 months to update this, sorry.)
