Author Topic: 12V Accessory Outlets  (Read 14941 times)
Offline timsatx
Re: 12V Accessory Outlets
« Reply #20 on: July 20, 2011, 11:02:12 AM »
I think what Snarf meant was that there are two bullets for each location.
Offline ATC Buckeye
« Reply #21 on: July 21, 2011, 05:33:40 AM »
I found a cheap socket at radio shack and mounted it in my topcase so I can charge my phone on the fly and itll be safe and soundi nside the case.  I drilled a tiny hole in the case, added a grommet and made the wires quick disconnect so I can still remove the case easy (not like I ever remove the case anyway).
Offline timsatx
« Reply #22 on: July 21, 2011, 06:58:04 AM »
The previous owner evidently tapped into and existing wire set to connect the outlet on my fairing, but it is hard mounted so I cannot easily remove the fairing. I can only remove it partially. Eventually I will fix that by using the twist connectors (brain fart, I can't remember the name). Then I can easily remove the fairing, or at least easier.
Offline bbroj
  • To be determined...
« Reply #23 on: July 21, 2011, 08:03:08 AM »
I hope you're not talking about wire nuts!? Buy some propper insulated male/female crimp connectors or a pair of SAE connectors and solder and shrink wrap them in.
COG 9331
Offline dras
  • The Invisible Man
« Reply #24 on: July 21, 2011, 10:48:40 AM »
Where is a good place to buy the SAE connectors? Most of the ones I see on eBay, etc. are quite small wire gauge like 16 - 18. I would like to get some with beefier wires, although I'm not sure what the current rating for the actual connectors is. Anybody know?
Dave
Never get too busy making a living that you forget to make a life.
Offline bbroj
« Reply #25 on: July 21, 2011, 11:01:58 AM »
I would just check the local auto parts store, or even a department store with a decent auto section. NAPA has several in the trailer towing section of their catalog, part # NW 784640, it's also 18ga. There are a few others as well.
COG 9331
