« Reply #19 on: November 03, 2011, 03:22:39 PM »
The handling will be affected - due to a lower center of gravity (at least). As stevewfl said, it's simple physics. Whether you find the difference objectionable (or even noticeable) is going to be subjective.
Agreed. And generally a lower center of gravity is a GOOD thing. Losing ground clearance is not. Losing a bit of extreme cornering/leaning might be or not, depending on how extreme you corner. In my case, it will never be an issue
![Smiley :)](http://zggtr.org/Smileys/default/smiley.gif)
There are subtle other changes- like spring rates, etc, that are also unclear as to being "good" or "bad", just different, many probably unnoticeable.
« Last Edit: November 04, 2011, 04:06:26 PM by maxtog »
![](http://zggtr.org/Themes/default/images/ip.gif)
Logged
