Get the bike back on the highway, doing a steady speed around 55-65. Watch your temp gauge for about five miles, to get an idea of what's happening. Showing just above ice cold(the "C" mark?) is normally a bit too cold, but after coming off the highway, the stat probably didn't close in time to reflect the less heat the engine was creating. Doing the above test will give a better indication of thermostat action. What most do in the cold is kinda cycle up and down within the lower side of the range.
Now, all that being said, your bike is 8-9 years old. If it's not been done, this winter may be a real good time to go through the entire cooling system, replacing all hoses, clamps, O-rings, thermostat, radiator cap, and of course, the coolant. Then you will know where you stand on this stuff. Having to disassemble a good chunk of the bike away from home over a $3 hose would/does really suck. BTW, I installed a 195* stat('83 Honda Accord), I like the way it keeps the temp up in cooler weather and it still works fine in the Floriduh summer heat.
