99.999% certain it's an Audiovox CCS-100. The Key pad is from the CCS-100.
Check these links out:
Manual:
http://www.gadgetjq.com/av_manual.pdfC10 instructions at Murphs:
http://www.murphskits.com/catalog/docs/audiovox/index.htmSounds like you have a loose wire. Check out the purple wire connected from the cruise to your brake light. If you loose the connection to the purple wire the cruise shuts off.
