Author Topic: 2011 Smoking when cold..........not outside temp, bike temp....  (Read 14894 times)
Re: 2011 Smoking when cold..........not outside temp, bike temp....
« Reply #20 on: May 18, 2011, 06:54:27 AM »
It is condensation and perfectly normal. As the exhaust system cools, it draws water into it and that water condenses against the cooling metal. When the vehicle is started again, the head drives the water into steam and you see the vapor exiting the muffler.
Nothing to worry about. If you are really concerned, note the crankcase oil level and see if it is going down.
All internal combustion vehicles do this although it is more obvious in the winter when the water vapor cannot be easily absorbed by the atmosphere and leaves plumes behind.
flying luggage or exploding drive shaft thread next please
« Reply #21 on: May 18, 2011, 07:09:54 AM »
Steve, just because it hasn't happened to you doesn't mean it doesn't exist for another rider...
« Reply #22 on: May 18, 2011, 07:12:01 AM »
I can't disagree, just stirring the pot
and honestly I've been expecting something lately
« Reply #23 on: May 18, 2011, 09:11:11 AM »
No way that is condensation...........did you also pull the air filter, and or take a look in the airbox?
Offline Pynikal
« Reply #24 on: May 18, 2011, 09:27:51 AM »
nope, i guess i could do that tonight.  after i wipe all the rain off it when i get home.....its gonna be a wet ride home.
« Reply #25 on: May 18, 2011, 10:03:02 AM »
if it was oil you'd more than likely see it all the time. i should submit a vid of all my bikes on a nice humid FL day after they haven't been started for a while  :P
« Reply #26 on: May 18, 2011, 10:03:52 AM »
ok, bookmarked this thread. Looking forward to seeing what this is (and may even check my panniers for looseness)
Offline JetJock
« Reply #27 on: May 18, 2011, 10:42:32 AM »
Not necessarily. Some BMWs long had a problem where if the bike was left on the sidestand for an extended period of time, oil would pool and then be sucked into the cylinder and burned on start up. I don't remember the years or models, but it was a known problem. BMW eventually fixed whatever needed fixing to prevent it. Sounds similar to this situation.
« Reply #28 on: May 18, 2011, 01:59:19 PM »
True but only the first generation K bikes, or 'bricks' from BMW had that problem and only then because the cylinders were horizontal and pointed 'down' when the bike was on the sidestand. It was a unique situation like the lower two cylinders on an aircraft radial engine and not the norm on virtually anything else.
It is possible that the original poster really has an internal engine problem but my experience says it is nothing but condensation. Of course he could have a cracked piston, cracked rings, missing valve guides and on and on but before I would even consider anything internal, I would check to see how much internal fluid is being used. My advice would be to NOT take anything apart 'inspecting' for this problem until there was some evidence that it was oil, or anti- freeze in the exhaust vapor.
Offline Wild_Bill
« Reply #29 on: May 18, 2011, 02:41:05 PM »
try holding a piece of paper at the exhaust and let the exhuast gas condensate.
you should be able to tell what type of fluid is left on the paper.
anti-freeze smell's like maple syrup
Of course you could just use a garbage bag to collect the exhaust....
Bill
Formerly known as Badnews_Bill
« Reply #30 on: May 18, 2011, 02:53:09 PM »
And then go to every single person you know, have them smell inside your bag, and guess what it smells like. Great idea Bill!
<snip>
Bill
Offline Pynikal
« Reply #31 on: May 18, 2011, 04:36:25 PM »
well i left work today and nothing.....temp was about 65 degrees and humid.
i must have had the oil level just enough over full to cause this.......weird.
ill keep an eye on it to see it the problem is totally gone.  thanks for all your input guys!
« Reply #32 on: May 18, 2011, 05:57:58 PM »
Seems that one Brian was right, and one Brian was wrong!!!!!! ;)
« Reply #33 on: May 18, 2011, 06:45:36 PM »
« Reply #34 on: May 18, 2011, 06:48:56 PM »
I hope that works out for you but I really did suspect nothing major was wrong. The oil level would have to be tremendously high to cause enough oil in the exhaust and even then that probably would not happen.
Usually there are quite a few symptoms and more than a couple of problems before oil consumption becomes apparent in the color of the exhaust.
