The method used to determine the behavior of the wires judged 'most likely' to have an effect, by myself, were chosen from the wiring diagram. Then with some pondering along with a pair of wire cutters, each wire was cut and a defective activation switch was simulated to determine the effect the circuit had on the system. Some knowledge is implied and some is direct but I assure you, disconnecting and reconnecting the wire I choose originally (way back in '08 or '09) will work to cure a faulty activation system. My bike has carried that circuit alteration for years and I have demonstrated it for several people when asked to do so.
The basic problem in 'tinkering' with the circuitry is that there are pieces of electronics in various places on the bike. We would like to think that the ignition switch simply fed wires into the ECU or some similar situation but the fact is that the ignition switch housing has its own circuit internally. We cannot easily get to that circuit. We can get to segments of those circuits via the connector mentioned but doing anything with those parts of the wiring has more widespread consequences than just interrupting the activation switch circuit alone would have.
If you believe you have a method to alter the behavior of a faulty KiPass circuit from under the seat, you can always do what I did and cut the circuit- it should become clear pretty quickly what that circuit does and does not do.
A bullet connector, especially one with just a dab of grease on it, would be an excellent solution in my opinion. I just do not believe there is a circuit under the seat where you can make use of it. But it should work very well if tapped into a correct (there are several choices) that feeds the ignition switch assembly.
Best of luck,
I read the instructions and one of the connections uses the green wire. It changes color at the gray connector, according to the wiring diagram, and makes a beeline for the ECU under the seat. If the green wire under the front fairing works, then so shoud the wire under the seat. Rather than a switch, I'm more inclined to solder in a bullet connector.
I'm curious how it was determined the green wire is the one. I haven't found a wiring diagram in the FSM for the ignition switch assembly.
As far as rodents go, I've had them cut wires under the hood of my car in very inconvenient places. So far they've left the bike alone.
