first picture clearly shows overfilled, and second shot shows what the "at rest level" should be . I tend to agree with Tony, on the overfilled thing. It also appears in the photos the engine in this area looks "shiney and wet" with some fluid mist coating....often this occurs on an over fill, and soon the waterpump oil seal will be a leaker....bt-st many times ...
No mention of the oil filter type, I'll note that a blocked or defective filter, or one that is not capable of the task, will force the oil to be bypassed thru the relief valve, which will definatly cause oil foaming. If you are dumping more than 3 quarts and 6 oz. in there you are overfilling (when the oil was drained using both drain bolts, and a new filter installed...)
