Author Topic: Fork oil height  (Read 1870 times)
Offline WiConnie
Fork oil height
« on: October 10, 2011, 07:25:46 PM »
Did a search...but did not find the 2 figures I need for my fall fork maint.
Probably has been asked a million times.....sorry ::)
1997 C10..
1....what is correct amount of fork oil per leg?
2...for better results what is correct oil height per leg. And, do you measure with forks extended or collapsed?
Thanks...
Barry
New to me 97
Germantown, WI
Offline Two Skies
  • Road? What road?!?
Re: Fork oil height
« Reply #1 on: October 10, 2011, 08:53:52 PM »
150 to 170 mm is sticking in my brain.  I'll look it up now and edit.
Edit:
From the Clymer's Manual:
Oil capacity per leg, 1994 on:
When Empty: 379 ML
Fork Oil Change: 330 ML
Oil Level each leg, measured from the top of the fully compressed fork tube without spring:
171 mm
Hope that helps!
Offline WiConnie
Re: Fork oil height
« Reply #2 on: October 11, 2011, 04:43:06 PM »
You da man!
Thanks...
New to me 97
Germantown, WI
