Author Topic: Everyonce in a While....groaning clutch  (Read 6089 times)
Offline lt1
  • 2008 C14
Re: Everyonce in a While....groaning clutch
« Reply #20 on: October 10, 2011, 12:49:08 PM »
It happens pretty regularly on mine.
Eyes, Brain, Hands.  Repeat.
Offline RIGS
« Reply #21 on: October 11, 2011, 05:55:05 AM »
Not a big issue, just curious if anyone else experienced it....
For what its worth, never heard it with my 08.
Thx for the inputs....
« Reply #22 on: October 11, 2011, 12:31:47 PM »
It sounds like a <k-word> issue to me....
It is hard to describe noises and how things are felt (easy boys!) but mine has what I would describe as clutch chatter, mostly when the clutch is pretty heavily loaded but still slipping slightly during launch. It seems to be oil viscosity related; the thinner the oil, the more it does it. Even more important that the actual weight of the oil in the crankcase is the temperature of the transmission; the clutch shudders mostly on hot days when the bike has been used a long time. On the other side, it does not do it at all once the temp. is below something like 45 F.
It is probably normal and I would probably ignore it unless it is progressive and getting worse, and then it should be taken care of under warranty.
While I am letting out the clutch and motoring away from a stop, the clutch makes a very odd groaning sound.
It happens randomly, riding single or 2 up....
Anyone else experience this?
Thoughts?
Its a 2010 with 21k miles....
Offline redbarber
  • '09 ABS (wife on '08 Can-AM Spyder follows)
« Reply #23 on: October 15, 2011, 09:14:40 AM »
... It seems to be oil viscosity related; the thinner the oil, the more it does it. It is probably normal and I would probably ignore it unless it is progressive and getting worse, and then it should be taken care of under warranty.
I have to agree with Brian, I usually notice it most when it's pretty hot, and least right after an oil change with dino oil.  The last two oil changes, using full synthetic oil at a lower viscosity, I've noticed it more, but worried about it less.
If you take yourself too seriously, nobody else will.  Humor is all around you, make it your quest to find all of it!
