Author Topic: spin on filter kit  (Read 4307 times)
Offline DarrellB
  • If your going to ride. Ride. Forget the trailer
spin on filter kit
« on: May 15, 2011, 07:59:35 PM »
With the spin on oil filter kit do you still need to modify the plastic on the bottom below filter area?
02 Connie with 06 Skin
Re: spin on filter kit
« Reply #1 on: May 15, 2011, 08:02:45 PM »
You do not have to cut anything...... If you want to run a LONG filter then you will need to trim the plastic to allow clearance. But that is not required to run the standard length filter.
Offline DarrellB
« Reply #2 on: May 15, 2011, 08:13:41 PM »
Thanks. That what I thought by looking at the photo on Murph's site.
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #3 on: May 15, 2011, 09:04:00 PM »
i don't understand why you wouldn't want to modify the bottom plastic. I see no point whatsoever in the plastic crossover piece, and cut it entirely from my belly pan. Steve
« Reply #4 on: May 15, 2011, 09:09:01 PM »
Just cause...... I only trimmed mine back with a piece of tupperware to make a half circle cutout.
Offline DarrellB
« Reply #5 on: May 15, 2011, 09:52:41 PM »
I may take a look at doing that.I guess anything that would make it faster means more time to ride.
