Author Topic: Symtec Grip Heater switch failure  (Read 2408 times)
Offline TRBN
« on: September 18, 2011, 02:26:52 PM »
Looks like my Symtec Grip Heaters Hi-Off-Lo toggle switch has died.  Other than replacing it like for like, are there any suggestions for a replacement switch that will have a longer life/easier to use?  A similar size switch replacement would be preferred so it can fit into the existing hole where the bad switch is removed from.
Aaron
Offline Tarheelbob
Re: Symtec Grip Heater switch failure
« Reply #1 on: September 18, 2011, 04:07:29 PM »
Two things to check:
1. Make sure the switch isn't grounding out on the metal stays behind the dash if you've mounted in the left side in the blank dash insert.
2. Check your solders and connections. I had just about given up on mine and re-wired it from stem-to-stern. Bad solder job on my part (cold solder joints) was the culprit. Works fine now.
« Reply #2 on: September 18, 2011, 04:23:38 PM »
I am sure it wound not fit but if you want to go with the ultimate in reliability, you might want to consider replacing it with a KiPass activation switch.
When you care enough to use the very best....
Aaron
Offline TRBN
« Reply #3 on: September 18, 2011, 10:54:15 PM »
1. Make sure the switch isn't grounding out on the metal stays behind the dash if yve mounted in the left side in the blank dash insert.
I pulled the switch out and cannot get any resistance value across the switch terminals when the switch is in either the Hi or Lo position..  So I am pretty sure its the switch.
Aaron
« Reply #4 on: September 19, 2011, 08:20:54 AM »
or if you don't mind carrying an extra key, the he could adapt the ignition switch from an FJR. I'm sure I can think of somebody who would agree...  8)
Offline TRBN
« Reply #5 on: September 19, 2011, 06:48:03 PM »
I'm messing with the switch this afternoon, using my multimeter to test continuity when the damn thing slips out of my hands...  4 foot drop to the garage floor, a bounce and a roll, and wouldn't ya know, the switch now passes current!!  Sure enough, hook the switch back to the grips and all is working normally...
Ordered a new switch anyway, but at least they are working now on the old switch...
Aaron
