Author Topic: How much paint?  (Read 3652 times)
Offline jim_de_hunter
How much paint?
« on: May 15, 2011, 07:05:10 PM »
How much paint do I need to repaint the Blue Monster a new color?  Is a pint enough or do I need a quart?
2006 ZG1000 "The Blue Monster"
Re: How much paint?
« Reply #1 on: May 15, 2011, 07:15:48 PM »
I would think that quart would be needed but I'm not a painter.
Offline Rick Hall
  • Eruption
Re: How much paint?
« Reply #2 on: May 15, 2011, 07:23:32 PM »
You'll need less than a quart, and more than a pint, @ ready to spray consistency. I did all panels 'cept belly, main fairing twice. And main fairing again a year later. Still have a few dregs in the bottom of the can. DuPont Chroma, SATA Mini Jet 4 HVLP gun.
Primer or primer/filler is another story, don't forget clear.
Rick
Re: How much paint?
« Reply #3 on: May 15, 2011, 08:08:03 PM »
I've not used a gravity fed gun yet.  Is it any different than a cup gun?
Offline Rick Hall
  • Eruption
Re: How much paint?
« Reply #4 on: May 15, 2011, 09:31:24 PM »
Both puke a bit of paint when you paint upside down  ;)
The good HVLP guns are a dream to work with, 105% of the paint goes on the part, not in the air then onto the floor (you hair, shoes, fingers, ...). The better ones (Sata and Binks are but two) are a bit pricey though (opinion).
You can use up all the paint in the cup, no waste. Unless you mix up WAY more than you need ;) Cleaning is a breeze, 1oz of solvent, slosh, spray, dump, repeat twice. Wipe down. They don't sit flat on your bench though, you need a hook of some type to hang it on while filling and during flash times.
The Mini-Jet I mentioned is a panel / touch up gun. Only has a ~4oz cup, but works for all I do.
Rick
