Author Topic: Givi Maxia e55, anyone using the top rack?  (Read 7239 times)
Offline ljcorby
  • COG#: 9359
Re: Givi Maxia e55, anyone using the top rack?
« Reply #1 on: September 18, 2011, 07:20:33 AM »
I'v got the E55 Maxia with smoked lenses and Admore lighting kit, but no top rack.  Sorry.
10 Kawi Concours 14 ABS
Offline overthehill
« Reply #2 on: September 18, 2011, 07:41:09 AM »
I have the top rack.  I used it on my FJR1300 and moved it over to the Connie.  I dont have pictures right now, but will get some taken later.  It was great for light items like a tent or bedroll.  It also worked for drying items like gloves when moving down the road.  Will post pictures later.
1987 Connie gone
2003 Goldwing (yikes, no lean angle) gone
1999 Connie gone
2008 Connie
Offline Texas Concours14
« Reply #3 on: September 18, 2011, 08:11:53 AM »
I have the top rack on the E52 - looks very similar to the photos of the top rack on the E55.  Easy install, and seems to be fairly sturdy even though it is attached to plastic (i.e., the top case).  I use it only for light stuff, but it comes in handy.
2010 C14 ABS
Offline philipintexas
    • Phils Farkels
« Reply #4 on: September 18, 2011, 10:49:16 AM »
Keep in mind the grab-rails are made of plastic, add a huge trunk filled with stuff and then a rack on top and you can easily exceed the posted weight limit of 22 Lbs.
« Reply #5 on: September 18, 2011, 04:37:12 PM »
I have a Givi 55 with the luggage rack on top of it. It works pretty well for large, bulky but light items like shoes.
I did not use the instructions or template to mount it though- I thought that was the difficult way to go about it. I just put the rack on the box where it should go, penciled circles around each of the four feet and then drilled holes in the centers of the penciled in circles. That method worked fine, was fast and easy and I think it was easier to drill through the case from the outside than it would have been to do so from the inside.
I've tried to find images of the e55 with the Givi top rack,  ??? http://www.google.se/search?q=Givi+Maxia+e55&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&hl=sv&tab=wi&biw=1304&bih=707#um=1&hl=sv&safe=off&tbm=isch&sa=1&q=Givi+Maxia+e55+top+rack&pbx=1&oq=Givi+Maxia+e55+top+rack&aq=f&aqi=&aql=&gs_sm=e&gs_upl=847l3333l0l3515l9l9l0l8l0l0l212l212l2-1l1l0&bav=on.2,or.r_gc.r_pw.&fp=3e26618764148bed&biw=1304&bih=707
But still haven't  found any... Only fitted to the e52... Anyone using the setup? Pics?  ;)
Offline Jojje
« Reply #6 on: September 19, 2011, 07:40:42 AM »
Thanks for the replies. I'ts for a tent, so I'll guess it'll work out just fine... Would like to se some pics still  ;D
« Reply #7 on: September 19, 2011, 02:41:44 PM »
Would like to see some pics still  ;D
Here's one (not mine, I think it's Wanderlust's):
Offline Khrome
« Reply #8 on: September 19, 2011, 02:58:01 PM »
LoL... nothing like a "top down" view ....   :rotflmao:
Khrome 2011 C14...09 Kaw Voyager...08 Yam WR250X...07 Yam FJR...06 Suz M109...04 Yam RoadStar...03 Kaw ZZR 1200... 02Kaw ZRX1200...01 KTM LC4...00 Kaw KLR 650...99 Kaw C10...98 Kaw ZRX 1100...94 Kaw Zephyr 750...85 Kaw 454LTD...79 Honda XL250S
Offline TonyR
« Reply #9 on: July 12, 2015, 09:27:02 PM »
I was looking for some pictures for a C14 with a Maxia E55 installed and ran into this...
I actually never realized the grab rails are made of plastic... I have the E52 mounted on my 08 with almost 40K miles and I have to say that I always load that trunk and put another bag on top of it. I never thought of breaking anything with loaded trunk,bad, and wifey leaning on it...
Tony
« Reply #10 on: July 13, 2015, 04:27:00 AM »
It isn't the grab rails you need to worry about....it's the plastic sandwich carrier on the back.
Offline Gigantor
