Author Topic: Generator Woes.  (Read 1956 times)
Offline TjTexasJack
Generator Woes.
« on: August 25, 2011, 05:56:46 PM »
  Well the generator on Conkankerous is on the fritz. What are the cost difference between rebuilding this one or getting one of steal-bey? Found one for 145.$ In that the bike is my only current mode of transport can get buy using charger, But need to fix ASAP.
Tested via multimeter and pulling battery lead anyother possable problem sources?
Thank in advance.
Tj
Offline SteveJ.
Re: Generator Woes.
« Reply #1 on: August 25, 2011, 06:30:34 PM »
I ASSume you checked the alternator output connection? They can over heat and break contact and do other ugly things.
America's Seaplane City
Offline midnightrider
Re: Generator Woes.
« Reply #2 on: August 26, 2011, 09:47:09 AM »
+1, and if its a regulator issue you can fix it yourself for around $70.  P/N ESR025
2004 C10 RIP
Offline GeeBeav
Re: Generator Woes.
« Reply #3 on: August 26, 2011, 11:18:02 AM »
. . . if its a regulator issue you can fix it yourself for around $70.  P/N ESR025
If you decide to go this route, make sure the rotor is not shorted before buying/replacing the regulator.
Offline RedWyvern
Re: Generator Woes.
« Reply #4 on: September 05, 2011, 12:08:01 PM »
Jack, get it worked out?
I picked up an alternator of ebay for $42 shipped... come to find out IT was bad too.  Got in there with the manuf spec sheets and found my rectifier was bad, and blessed be his regulator was.  Since the regulator is much easy to remove, I put mine in his.  He was nice enough to refund all the money as it was not as described and not worth the money to ship back.  I did offer to go half and half!
Def check the output on the alternator, because as Steve mentioned the connector up behind the battery can crusty up, burn and melt.
Aftermarket rectifier is $80.
