""Ended up being the thermostat switch again. I've changed mine 2x in the last twenty years.""
I doubt the water pump is bad. Not much in there to fail and if it did it would no doubt leak coolant or make noise or both.
you're talking about the "water temperature sensor" (Kawi terminology) that fits into the thermostat body......?....correct? What auto store carries these??? (in your neck of the woods at least) and what did you ask them for at the counter? Do you have the manufacturer and part # of the auto parts sensor that fit yours?...and what year is your Connie?
I'm afraid I have to order this from Kawi. IF I could find it at a NAPA that would be great. thanks
