Author Topic: ebc rotors and sintered pads  (Read 7082 times)
Re: ebc rotors and sintered pads
« Reply #20 on: February 21, 2013, 07:42:48 PM »
EBC rules  8)
« Reply #21 on: February 21, 2013, 08:21:36 PM »
EBC rules  8)
This. Been running them on My bikes as long as I can remember. Pretty sure the first set I installed was on my ZL900 Eliminator, back in 1985.
« Reply #22 on: February 22, 2013, 04:00:31 AM »
I found the problem...
Glad you found the issue and thanks for giving the update.  We see lots of calls for help and then no feedback as to what the problem/fix really was.
« Reply #23 on: February 22, 2013, 07:21:45 AM »
Cheers!!!!!!
Offline stewart
« Reply #24 on: February 28, 2013, 07:07:50 PM »
Slightly off topic, but is there a recommended after market pad for stock rotors?
Stewart
2010 Concours14
COG 9380
Offline Cheesecake
« Reply #25 on: February 28, 2013, 09:06:52 PM »
Stick with the Kawa pads unless you have a some reason to change. I used EBC just because I always have, and went back to Kawa pads because of the noise, they make a raspy racket when braking.
2008 C-14
Offline dolomoto
  • '08 C14 "Hot, Nasty, Bad-Ass Speed"
« Reply #26 on: March 02, 2013, 06:35:28 AM »
I use the EBC HH pads with good results. IIRC the OEM front pads went about 25k, replaced by EBC HH pads which went until I changed them when I changed the rotors...so they went about 40k. The OEM rear pads went 56k and were replaced by EBC HH pads also. I change the brake fluid about every year (made easier with SpeedBleeders!)
As to the longevity, I do a lot of highway miles.
