Author Topic: Valve Adjust spreadsheet (Found on net but awesome)  (Read 10255 times)
Offline Mad River Marc
  • The Kipass shall inherit the earth
« on: August 19, 2011, 10:19:11 AM »
Was surfing around and came across this VERY detailed spreadsheet for mapping the valves on a C-14.  Has a tab that lists all the shim sizes and a tab for MM and a tab for Inches
I cannot take credit for this as it was created by Kory on the ZZR forums....
Sofa King
Re: Valve Adjust spreadsheet (Found on net but awesome)
« Reply #1 on: August 19, 2011, 12:03:10 PM »
NICE!  Thanks for posting!
Offline SonnyC
  • Live long and enjoy life to its' fullest.
« Reply #2 on: August 20, 2011, 12:32:14 AM »
Gratis!  I saved it and will definitely use when it is time to the the valve inspection/adjustment.
SonnyC
Offline Texas Concours14
« Reply #3 on: August 20, 2011, 01:08:21 PM »
Thanks for posting this file.  I have seen postings of handwritten shim notes that looked very intimidating.  This spreadsheet will be helpful when time comes for me to adjust the valves.
2010 C14 ABS
Offline McJunkie
« Reply #4 on: August 21, 2011, 07:43:20 AM »
Damn. That looks amazingly like the one I did. Someone added the shim sizes to it. I also added a second page for the specs after re-shimming for comparison.
Offline klb1122
« Reply #5 on: August 21, 2011, 08:40:17 PM »
Holy smokes, that's my spreadsheet!   :o   8)
Your search must have lead you to the zzrbikes.com site.   ;)
I hope people get some use out of it.  I created it to do my valves, then I did my dad's C14 with it as well.  I'm about due for a second check on mine, hopefully no adjustments will be necessary this time.  I'm pretty sure I adjusted every single shim on mine and dad's the first time through.
I made it a while ago, probably looked at several others before I created it.  Then I made one personalized for me.
Offline jonathan
« Reply #6 on: August 22, 2011, 09:02:01 AM »
That is an amazing peice of work! Thanks.
« Reply #7 on: August 22, 2011, 09:51:15 AM »
KLB you are correct, I came across it on the ZZR forum and it was just too detailed to not share with the rest of Cogdom :)   In the spring I will prob be tackeling my valves and will use this.
Hoping that I don't grenade my motor LOL
« Reply #8 on: August 22, 2011, 10:33:00 AM »
Awesome! This is another tool that will make me more likely that I will do the valve adjustment myself when it is due.
Offline jonathan
« Reply #9 on: August 22, 2011, 11:58:18 AM »
I had some spare time, so I have updated it so that you now only need to enter 2 values. The Existing Shim Size, which is now selected from a drop-down box, and the Measured Clearance. Everything else is calculated for you. Hopefully this will make it easier to use and help to eliminate errors.
Offline klb1122
« Reply #10 on: August 22, 2011, 12:37:21 PM »
Nicely done, Jonathan!
I didn't share it with the masses because I didn't want anyone blaming me for exploding engines.
Now we can all blame Jonathan.   ;D
« Reply #11 on: August 22, 2011, 12:52:14 PM »
Wonder if we can get one of the forum admins to sticky this!
