Author Topic: Tire compressor on board?  (Read 6080 times)
Re: Tire compressor on board?
« Reply #20 on: August 16, 2011, 07:24:27 AM »
Tiny slime compressor FTW
Offline SVonhof
  • 2009 C14
« Reply #21 on: August 16, 2011, 07:40:59 AM »
I cant show you any pictures. The compressor is behind the battery where the ABS computer is located. On an 08 this place is just an empty space. Big enough for two of the slime compressors. I don't know if there is enough room on the ABS models to to squeeze one of these small compressors in there. Just pull the battery out and take a look in there.
Thanks. I have an 09 non-ABS model, but was more wondering how you are holding it in place than anything. I wouldn't want it sliding around or free to move or bounce.
Scott
Offline C1xRider
« Reply #22 on: August 16, 2011, 10:11:02 AM »
http://www.murphskits.com/catalog/product_info.php?products_id=462
Coffee Break on the C10 forum tested it out:
 "A new tire repair kit--from Murph!"
Manufactour claims no ill effect on TPS
....I don't want be the first to see   :o
 8)
Murph
COG 2769
Industry Member
Murph, you're missing some critical information about the pump on that page : Dimensions and weight!
Offline Two Skies
  • Road? What road?!?
« Reply #23 on: August 16, 2011, 01:24:23 PM »
I ended up with this particular kit in my trunk.
http://automotive.hardwarestore.com/90-545-tire-inflators/spare-tire-repair-kit-660593.aspx
Haven't had to use it yet, but I stuck a plug kit in the plastic/nylon bag to boot.  It has the 'flippy' end on the compressor hose, so it should remove quickly.  It doesn't take up a lot of space, and I suppose you might be able to fandangle it into the space behind the battery, but I haven't tried (that's what my trunk is for).
