Author Topic: jump starting the bike  (Read 9225 times)
Offline speed545
« on: August 01, 2011, 07:56:31 AM »
hey guys
i m stuck in Front Royal and battery is dead. How can i jump start this bike
08, Concours 14
Montreal Fire Dept
Offline stewart
Re: jump starting the bike
« Reply #1 on: August 01, 2011, 08:06:00 AM »
I was able to jump start mine last year will the help of a push and a small inline. I used 1st or 2nd ( don't recall), but the key I think was my battery wasn't completely dead, I could turn on my ignition.
Stewart
2010 Concours14
COG 9380
« Reply #2 on: August 01, 2011, 08:41:24 AM »
Well, for one you'll need battery jump cables.  You'll need to remove the panel covering the battery.  Hopefully you'll have the tools to do so.  Once the battery is exposed (assuming it's installed properly), the positive terminal should be facing you (verify this first, please).  You can connect to that and to the frame mount for the negative side.  Have the jumper car not running when your ready to try to start it.
I'd come out there but you're a good two hours away from me.
Offline philipintexas
    • Phils Farkels
« Reply #3 on: August 01, 2011, 08:43:13 AM »
If you have to jump it do it as you would an automobile, at the battery. A car can be used as it is 12 V. just dont run the starter for prolonged periods. As far as push starting it a higher gear may make it easier, say 3 rd. or 4 th.
Offline stewart
« Reply #4 on: August 01, 2011, 09:12:07 AM »
small correction when I said inline, I meant incline.
Stewart
2010 Concours14
COG 9380
Offline JetJock
« Reply #5 on: August 01, 2011, 10:51:29 AM »
What he said. What I did when I left the key in the "On" position for a few hours. Hardest part was finding the strength to loosen the allen head bolts the gorilla at the factory installed!
Offline fmwhit
« Reply #6 on: August 01, 2011, 10:59:30 AM »
If you decide to try bump starting the bike remember that the battery needs to be capable of at least putting out enough current to operate the fuel pump as the bike is fuel injected and some of the other electronics on the bike such as the ki-pass.
As far as jump starting the bike just remove the battery panels and carefully hook up the cables, remember the connections are alot smaller that an automobile.  I prefer to use a jumper pack if one is available.
Good Luck,
Fred
Offline C1xRider
« Reply #7 on: August 01, 2011, 11:24:51 AM »
Also, since no one stated this clearly, the battery cover is the small right side panel about where your knee is if you are sitting on the bike with your foot on the footpeg.  As I recall, you need a 6mm Allen wrench to remove the single bolt holding it on.
Offline JetJock
« Reply #8 on: August 01, 2011, 04:09:32 PM »
You recall wrong. There are two covers, an outer one and then the real battery cover.
« Reply #9 on: August 01, 2011, 04:53:46 PM »
Yep, you gotta take the upper plastic one off first.  Then you can remove the metal one...
Of course, while we're all debating this, what happened to the OP?
« Reply #10 on: August 01, 2011, 05:37:27 PM »
That is correct but just to flesh out the answer a bit- the battery compartment is covered by the battery compartment cover or hatch. That is an aluminum casting and is held in place by four screws and appears to be a structural part of the frame. On top of that hatch is a small part of the fairing (painted the same color as the bike), held in by one screw and a push pin. To access the battery, the fairing cover must be removed and then the actual battery hatch must also be removed.
Offline speed545
« Reply #11 on: August 01, 2011, 06:04:15 PM »
thx guys.
the battery was completely dead. Hotel staff didnt want to provide cable an a car battery since they were afraid of me broken something and get them after. Dont know ???
I was able to reach the battery with no difficulty buy lack of cable got me. >:(
Anyhow, i used my road side assistance insurance and got the bike towed to the winchester kawa dealer. He wanted to recharge the battery but since i just began my trip (11 days left) , battery is 4 year old, what the heck, i bought a new one.
They were very nice to me. Took the bike in immediatly during lunch time.
Thx Virginiajim for youir thoughs about coming
I m now resting in Roanoke. Well deserve
08, Concours 14
Montreal Fire Dept
Offline C1xRider
« Reply #12 on: August 01, 2011, 08:50:45 PM »
Not surprised, I've only looked in there once, and it was months ago.  I thought you could get to the positive terminal without removing the metal cover, but again, I don't remember.
The main point of my post was to tell him where to start looking for the battery.  If you've never looked for it, and don't know where it is, a hint at where to start is a good thing.
« Reply #13 on: August 01, 2011, 09:27:29 PM »
I believe you are correct that it is possible, but very difficult because of the red rubber bootie.  So difficult that it really is not quite possible :)
« Reply #14 on: August 01, 2011, 11:20:58 PM »
thx guys.
Glad you're OK now
Offline C1xRider
« Reply #15 on: August 02, 2011, 01:48:38 PM »
OK, for the record, I was curious and had a few minutes to spare this morning (a rare thing) ...
On the 2010, you do not need to remove the inner metal cover that holds the battery in place.  Also you do not need to remove the plastic push pin / rivet.  The bolt holding the outer plastic cover in place requires a 5mm Allen wrench, not 6mm as I thought, and is the only bolt you need to remove.
If you look at the pictures below, you will see there is a cut out in the left vertical side plastic guard, that provides just enough room to connect a jumper cable to to the metal part of the cable.  You simply push the red rubber boot down the cable out of the way.
You do want to be very careful, so you don't short the jumper cable to the metal surroundings, but there is enough room, and the metal has a real nice coating of non-conductive paint.  Perhaps the 08/09 bikes are different, so if they are, someone else can chime in for them.
Also, if you ever find yourself stranded, and needing a jump, try calling a Taxi.  My buddy and I were stuck in downtown Tacoma once with a dead battery (another story), and he called a Taxi to swing by and give us a jump start.  I think they charged him $10 (or less), and it only took them a few minutes to get there.
Offline JetJock
« Reply #16 on: August 02, 2011, 03:59:23 PM »
Nice, didn't know about the little cutout access port. Obviously designed that way.
When I killed the battery on my 2010 I took both covers off just to be sure what I was dealing with, since it was the first time diving into those depths.
And with regards to jump-starting, good bike shops have 6-ft jumper cables that take up little room and can save your uncharged-ass in situations like this.
« Reply #17 on: August 02, 2011, 04:24:53 PM »
you do not need to remove the inner metal cover that holds the battery in place.  Also you do not need to remove the plastic push pin / rivet.  [...] you will see there is a cut out in the left vertical side plastic guard, that provides just enough room to connect a jumper cable to to the metal part of the cable.  You simply push the red rubber boot down the cable out of the way.
That is kinda what I said in my posting already. that it is possible but difficult (I guess I should have added "possibly dangerous"!)
Thanks for the pics!
« Reply #18 on: August 02, 2011, 06:52:14 PM »
Good tip, never thought about that option...  :thumbs:
