Author Topic: 2004 model 4-pot brake upgrade  (Read 11695 times)
Offline jim snyder
Re: 2004 model 4-pot brake upgrade
« Reply #20 on: August 03, 2011, 09:17:21 PM »
Brian / Jim - I notice that the rotors you linked above are replacement for the 94-06 Connie, so they are 300mm, not 320mm.
If you want 320mm for exact fit on the 94-06 Connie, look for replacements for the following bikes (among others) which came with 320mm stock and the correct bolt pattern / offset:
93-01 ZX11
00-03 ZX12
The 94 thru 06 rotors are 300 m/m, 320 would be over size for the stock brackets
Offline 2fast
  • COG #6497, North Central Area Director
    • C-10 Heat Shield photos
« Reply #21 on: August 03, 2011, 09:31:11 PM »
True true. I think the better upgrade for the newer models would be just a better caliper.....300 is already a decent size. In my case, the improvement was pretty huge going from a stock 270mm with a single pot to 320mm with 4 pots.
Brian in Minnesota
Need Heat Shields for the C-10? 86-93 Front Brake upgrade brackets?  I got em! Click the little green globe under my Avatar on the left.
Offline jim snyder
« Reply #22 on: August 04, 2011, 02:31:00 PM »
I agree. The biggest improvement is definitely the caliper. I also used the GSXR-750 Tokico calipers with the stock 300m/m rotors. I probably wouldn't go to the 320m/m rotors unless/until my 300's go bad.
enim57
« Reply #23 on: August 06, 2011, 07:19:09 AM »
It's the calipers that make the biggest difference, increasing from 300 to 320 discs will only give a 6.7% increase (torque = force x radius). When I did the upgrade for the earlier models I calculated there is 33% more pad area and 133% more piston area.
So I am looking for info on the 4 pot mod to the older Connies. Cost? Parts needed? Thanks
If you're using the stock size discs of 270mm diameter I can supply brackets to suit Nissin 4 piston calipers, I don't have any in stock at the moment though. See link below:
http://gtr1000.yuku.com/topic/3638/4-piston-brake-calipers
Regards, Russell
