I figured I'd update here... been a while.
![Smiley :)](http://zggtr.org/Smileys/default/smiley.gif)
...the new pistons showed up this week, so I tore it all the way down to swap 'em out. To re-cap for people who don't know: it turns out our C14 pistons are CAST, not forged items like the ZX14's. This is bad. I wanted to replace them with forged items, but ZX14 forged pistons that everyone makes are either way too high of a compression ratio (12:1+), or way too low (8:1-9:1). I wanted to retain the stock compression ratio, so I measured all the relevant parts and came up with the piston volume I'd need to make a 10.5:1 piston in our C14. Do note that this is different from the zx14 because of our slightly different cylinder head. I tried to contact a few piston manufactures, but the only people that would get back with me were Wossner (
www.wossnerpistons.com). I did some homework on the ZX14 forums and people had nothing but good things to say about them, so I gave them a call. First off, they are helpful, responsive, and knowledgeable about what they do. Second, they were more than willing to help make what I needed. They have an off the shelf Zx14 piston that was way too low a CR for me, so I asked them to make me a set of exactly the same piston... just with my specified (smaller) dish volume. Everything was done over the phone, and they got it right the first time. Lead time on a set of custom pistons was 4 weeks to the day, but now they have the drawing on file for this set up.
They did all this with great communication, no money up front, and all for 100-200 dollars cheaper a set less than JE or CP. And these pistons came with new rings, wristpins, clips, and coated skirts. Just wow.
Here are some photos and specs on the pistons. My camera batteries just croacked, so I'll post some stock piston comparison photos later on. The Wossner pistons are, unbelievably, TWENTY GRAMS lighter than the stock pistons, but they have wider skirts and better wristpin support. The wristpin bores are not tapered at the ends (the stockers are), so they weight an additional 6 grams... but are much stronger. The 1st and 2nd rings on the wossner pistons are much thicker than stock, so the ring pack weighs a few additional grams as well.... but again, are going to be stronger (and transfer heat to the cylinder walls much better!). Total weight (rings, wristpins, and piston) still came in a full 6 or so grams under the stock weight. As a bonus, everything was delivered weight matched within one tenth of a gram (0.1g). I've done a lot of engine balancing a few years ago, and it is damn uncommon to get a set that close right out of the box. For reference, I just matched up a set of off the shelf CP turbo pistons for a SR20 a few days ago... there was a .7 gram spread over 4 pistons there.
Vent holes in the oil ring are larger and more numerous than stock, and the piston dishes came fully de-burred and smooth. The valve relief cut-outs are rounded instead of sharp like the stock pistons, and the quench area is fully twice the size of a stock piston. Anti-wear/anti-friction coatings on the skirts is a nice touch too. I don't work for these guys, and they didn't give me any sort of special deal.... but I will sure as hell recommend them to anyone now.
![Cool 8)](http://zggtr.org/Smileys/default/cool.gif)
![](http://i42.tinypic.com/amzf52.jpg)
![](http://i40.tinypic.com/158qya.jpg)
![](http://i42.tinypic.com/15nm2s4.jpg)
![](http://i42.tinypic.com/35mk56e.jpg)
