Author Topic: Rostra install foiled (temporarily?)- California C14 sold in Texas! Help!  (Read 10645 times)
Offline Yankee270
Hey Brian.  The resume/accel is not working while I'm riding after I set a speed. I've test rode the bike probably 5 times and is he same thing everytime.
If you are certain both switches function properly then I would put the actuator into diagnostic mode and check that the actuator itself is getting the signal from both switches (resume and accel). If it is then the only thing I can think of would be a defective actuator. I have not heard of anyone having that problem before but I guess it could happen.
Offline Yankee270
I think it must be the actuator also.  Don't know what else it could be.  :(
Well by now you may be ready to rip it out, but before you do, double check the dip switches especially #12 it should be OFF.
Then do what Brian suggests and redo the diagnostic mode, if you are then still perplexed call Rostra as they are helpful.
The one time I didn't get an answer they called me back in 15 minutes just from my caller id since I didn't leave a message.
Do the green LEDs under the switches come on when you turn on the ignition? Does the center green LED light up when you do get it to work?
I just returned from Chicago and the Rostra worked great whenever I used it, even when I adjusted it up and down again and again for the monotonous, all too frequent construction zones.
Good Luck.
