Well, here it is - my 2011 Concourse with highway pegs installed! The key ingredient to meeting the challenge of a mounting platform for the highway pegs is the R&G Racing Adventure Bars (fairing/engine guards), sourced from R&G's US distributor, Twisted Throttle. Installation time 1-2 hours depending on level of mechanical skills. These bars are 22.5mm - 7/8" and that presented the second challenge of how to mount the highway pegs. The Kuryakyn and RIVCO peg mounting units I was interested in are primarily designed to be mounted on bars that are 1"+ in diameter. I wanted to use the RIVCO mounts because they move the pegs 6" forward and the Adventure Bars are set too close to the rider to get any real leg extension if the pegs are mounted directly on the bars. The fortuitous solution, which appeared after a lengthy series of internet searches, is a 22.5mm - 25mm (1") adapter sleeve from Ilium Works, an aftermarket accessories operation that caters primarily to the BMW "Adventure" set.
I used the RIVCO pegs because I already had a set in both chrome and black. I decided to use the chrome because the mounting arms are chrome. RIVCO also makes a much larger/flatter footpeg similar to the big Kuryakyn pegs. All RIVCO pegs and mounts are 3/8" bolt size in contrast to Kuryakyn which uses 1/2". A very nice feature of the RIVCO pegs is an allen-head "jack" screw that allows you to easily adjust the angle of the pegs.
The cost for the components I have listed below and as shown in the photos is about $550 if you include shipping costs. Since I installed them myself, there was no labor involved. My Kawasaki dealer (Twigg Cycles, Hagerstown, MD) gave me an estimate of around $150 to install the Adventure Bars (1-2 hrs). Once I had the adapter sleeves in hand, the installation of the peg mount arms and pegs took about 1.5 hours with adjustments. It is tight getting an Allen wrench in between the fairing and the mount in order to tighten the clamping screws. These have to be tightened very securely to keep the mounting arms from rotating when you have your feet on them. Once tightened adequately, however, they are very secure.
Parts List for Highway Peg System
Twisted Throttle
http://www.twistedthrottle.com/R&G Adventure Bars Kawasaki GTR1400 Concours '08-
Twisted Throttle Item No: RG.AB0002BK $330.00
http://www.twistedthrottle.com/trade/productview/6763/602/http://www.rg-racing.com/browseBike/Kawasaki/GTR1400_Concours/2010/AB0002BK.aspxRIVCO
http://www.rivcoproducts.com/1" Highway Peg Mounts for Honda GL1800 SKU: GL18004 $139.95
http://www.rivcoproducts.com/products/product.php?productid=29&cat=221&page=1Anit-Vibration Pegs - Chrome (pair) SKU: PEGS $44.95
http://www.rivcoproducts.com/products/product.php?productid=55&cat=221&page=1Ilium Works
http://www.iliumworks.com/22.5MM-25MM SLEEVE, HIGHWAY PEG 19-XXX $10.00
http://www.iliumworks.com/Store_Detail.cfm?ID=230519&InfoID=5919&ShowLarge=TrueSince you can only upload 4 photos, I have posted more photos showing more views and details on my website:
http://rosser.rsf3.com/concours1400highwaypegs.htm
