Author Topic: Test assist, please  (Read 9042 times)
Offline GeeBeav
Re: Test assist, please
« Reply #20 on: July 21, 2011, 10:03:39 AM »
I would be willing to bet that the kawasaki specail tool is probably just a version of this
http://www.fluke.com/Fluke/usen/Digital-Multimeters/Fluke-88V.htm?PID=56148
which includes the 10 meg ohm input impedance to protect the circuits your checking. Thats why we use them in aviation.
The specified kawasaki "hand tester" is analog - there were very few, if any, hand-held DMM's available when this manual was published.
Input impedance is irrevalent when testing ohms - the meter's open-circuit test voltage is the variable here. A digital meter's typical 2.5 volt test voltage may yield a different reading than a Simpson 260's 1.5 or 9 volts (depending on range).
Offline bbroj
  • To be determined...
« Reply #21 on: July 21, 2011, 10:12:36 AM »
What were the symptoms of the ones that failed? Did the bike still run (mine does)? I am wondering if several of us are running bad CDI boxes and don't even know it. The one I used to test gave the same readings, so I still have no comparison to a tested good box.
I have and used a Fluke 8021B, which is also 10 meg input on all scales. The Simpson 260 I used initially, well, I know it to be a quality meter, but I can't find the specification for the input resistance.
EDIT: I should know better than to post when the kindly red message pops up telling me someone has posted while I was typing and I may want to review my post. Nah!
COG 9331
Offline midnightrider
« Reply #22 on: July 21, 2011, 11:39:26 AM »
bbroj, the original box would drop two cylinders once warmed up. I could hit it with cold spray and bring them back. The second one was a $25 ebay box that worked for a few months then developed a miss all the time. I got another one from ebay and so far I'm good. I believe what killed the first box was the regulator going out on me and allowing the alternator to pump out upwards of 17 volts at rpm. It killed the battery, then with new battery and regulator installed it had the hot missfire.
GeeBeev, your correct. Most tasks I use an ohmeter for specify low volt and 10 meg input, but its the low volt thats most important. I didn't think it through all the way before posting.
2004 C10 RIP
Offline bbroj
« Reply #23 on: July 21, 2011, 11:56:16 AM »
Thanks, so it seems like I'm still on the lookout for a CDI box that tests out good to swap for mine to see if there is a change. Outback Jon, you still watching this thread? If your offer is still open, it may end up being at the National (I assume you will be there?). Weekends are in short supply, and Kathy and I will be taking our first run in the new-to-us RV this weekend, so that's out. If we were taking the bikes with us, as we plan to do in the future, it would be perfect, as we are camping in Saugerties.
COG 9331
Offline Outback_Jon
« Reply #24 on: July 21, 2011, 11:32:51 PM »
Not going to make the National.  I work midnights, so if a weekday works for you, let me know.  We could make it dinner instead of lunch if necessary.
Offline Summit670
« Reply #25 on: July 22, 2011, 09:37:49 AM »
Remember, you can try another IC box in your bike OR maybe someone will be game to let you try your box in their bike to see if it makes theirs run bad.
Arctic Cat M8 163 rules
Offline bbroj
« Reply #26 on: July 22, 2011, 01:59:14 PM »
Jon, sorry to hear that you won't be making the National, and the fact that you're working midnights (BTDT :() If Kathy and/or I have time before the National, I/we may still be able to take you up on the offer. If not, I'm willing to bet that someone at the National will be willing to oblige me.
Summit, that was my hope all along, to swap with someone whose bike runs well, and the box tests per the manual, and see if either of us noticed a difference.
COG 9331
Offline bbroj
« Reply #27 on: August 07, 2011, 12:39:55 PM »
I just checked mine, still the OEM ignitor, all readings w/in specs. 1886-1993 Service Manual, 1994 Connie with 167k miles. I did paint the bike blue a few years ago, installed SteveJ's old Russell seat further back, and recently installed SiSF's sprocket mod. Other than that...
I have a slight burble till off idle, and can't wring her out past 128 w/o a tail wind.
Rick
Rick, I just met with Outback_Jon and tested his CDI box as well. At first I thought his tested out as per the manual and I went to check mine against his. I realized, almost by accident, I had tested Jon's in reverse polarity according to the manual and it DOES matter. When tested in the polarity dictated by the manual, his tests the same as mine. Not accusing you of shoddy workmanship by any means, but is there any chance when you tested yours, the polarities were reversed? I'm still wondering if there is a possible issue with the procedure in the book. If you tested correctly, there seem to be a lot of these units that seem to run fine but fail the pass/fail in the book. I'm still confused... (no big surprise, I know  :nuts:)
COG 9331
« Reply #28 on: August 07, 2011, 01:14:48 PM »
Good Lord...some people on this board are just plain miserable. I can't believe anyone would go to you for help in the first place. Obviously God-complexes are not reserved for the medical profession.
Thank you for being "out".
just saw your quip, very nice. Did you know that there is also a book called "motcycle mechanics for dummies" ?  (I like your avitar, it fits well....) Might want to read that book, and about 30 other specific ones, spend 40 years repairing bikes, and hold the Tech Editor officer's postion for the COG for acouple years, along with a few thousand happy customers here that recieved concise and accurate assistance before spouting again.....
in the words of the famed Will Sonnet (old cowboy show, likely before you were born)
"No brag, just fact...."  http://www.fiftiesweb.com/western-5.htm
 :hitfan: :stirpot: :rotflmao:
http://youtu.be/9j1qkorFszY
on a lighter note,
BBroj, have you figured this one out yet?
or is it still running bad?
Offline kathybrj
« Reply #29 on: August 08, 2011, 07:46:37 AM »
Old tv clips...holy- you need to join your local senior center and play some card games or something.
Nice that you can still recall ALL the way back to your elementry school years in an attempt at an insult, though.
Those one-room school houses did produce some incredibly clever kiddies that are still alive!
You must have been a hoot before electricity!!! :rotflmao:
Those that need to pat their own backs are just sorry people- self esteem issues. Too bad you didn't address that earlier in your life. Probably too little time to take care of it now.  :'(
You really do have my pity, Old Man. That's about all I can muster for the miserable likes of you.
bbroj's better half
'14 Honda CTX 700
Offline Rick Hall
  • Eruption
« Reply #30 on: August 08, 2011, 08:00:53 AM »
...  but is there any chance when you tested yours, the polarities were reversed? ...
Anything is possible, but I stand by my readings. I'm using an analog Triplett VOM. (digital is just a fad ;) )
Something to ponder, are all the 'bad' IC units tested with the same multi-meter?
Rick
Offline Boxer
« Reply #31 on: August 08, 2011, 10:14:09 AM »
According to the schematic for the J Box here http://www.cog-online.org/clubportal/clubdocs/1328/ConcoursJ-BoxSchematicGBY2.pdf
pins 4 and 5 should show infinite resistance.  Those points look like an uninstalled option circuit.
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery..." Winston Churchill
Offline Outback_Jon
« Reply #32 on: August 08, 2011, 02:42:31 PM »
The testing that's been ongoing at the moment is of the ignitor box, and not the J-box.
Rick - We tested bbroj's and my ignitor at the same time, with the same analog meter.  I haven't noticed any issues with my bike, so I'm assuming mine is good.  His tested the same as mine, with infinity (open) between pin 4 and 5, but pins 4 and 5 to any other pin had continuity.  (With resistance)
Offline bbroj
« Reply #33 on: August 12, 2011, 12:34:41 PM »
Rick
I thought about that myself, and I did use different meters just to be sure. I used a Triplett VOM that I carry on my bike to test Jon's and a few others, including my own. At home, I tested mine using a Simpson 260 as well as a digital at work for comparison. At this point I am convinced that my ignitor is not an issue, but I am not yet convinced that the book is accurate on the test procedure. I even swapped with SNARF and we rode with each others ignitors, neither of us noticed a difference. I am becomming more and more convinced after seeing and hearing many other C-10's at the rally, my bike may be not be doing anything out of the ordinary. a can of Seafoam over the next few tanks just be be sure things are squeaky clean, and I forget it and ride!!
P.S. What a great time at the rally, sorry more of you couldn't have been there. We're making plans for Eureka Springs, Ak, starting now!
« Last Edit: August 13, 2011, 05:11:41 PM by bbroj »
COG 9331
« Reply #34 on: August 13, 2011, 02:50:02 PM »
.....I am becomming more and more convinced after seeing and hearing many other C-10's at the rally, my bike may be not be doing anything out of the ordinary. a can of Seafoam over the next few tanks just be be sure things are squeaky clean, and I forget it and ride!!
good to hear that, I am glad that the problem was not as serious as you once thought, and that is easily cured, something I eluded to initially from the symptoms you noted. I really feel a bit sorry that your wife had to interject, and sling insults during the initial stages, when I was trying to make a point (albeit a bit wrong in my mannerism, but I was trying to prevent you from "hunting dragons"), it still angers me that she found that necessary, but hey, I'll just consider the source. Glad the bike is fine, and feel free to contact me for any help I may be able to provide on maintaining and servicing the Concours motorcycle.
Offline bbroj
« Reply #35 on: August 13, 2011, 03:17:04 PM »
If you re read my initial post, I never asked for help with the running problem, just to see if the CDI test in the book was accurate, which you never did bother to reply to or help with. Telling me "I don't have the time, nor you the money..." and
"you did drain and clean it didn't you.....??
mmmmmmmmmmmmmmmm??" among other snide remarks touting your resume' and superior skills were to me, clear opening shots in the insults exchanged. My choice is to ignore such replies and focus on those that choose to offer the help requested. My wife tends to say what's on her mind and she nor I will apologize for it. Now you continue to insult my wife, offer me what seems to be a half baked appology (albeit a bit wrong in my mannerism, but I was trying to prevent you from "hunting dragons") and an open invitation to come to you for help? Keep it!
COG 9331
« Reply #36 on: August 13, 2011, 04:40:24 PM »
I fully read, and understood your initial post where you had a stumble, and felt it was electrical. I also understood before my posting you found discrepencies in the tests as per the manual, no issue. I offered an explanation/statement in an attempt to prevent you from chasing a problem that in my mind was not related to what I felt was chasing the wrong suspect in the running issue, which you DID state in the initial post....you had an issue with the way the bike was running.
My last statement was not asking for an appology, it was just to see the final results, of all the effort put in trying to find the cause for the running issue, which in reality you seem to agree may be some fuel issues.
I did not make the last post with intent to insult, and kept it very congenial, I have know idea why someone would be so adament as you are at this point to look past the sincere notation that I was happy to hear there wasn't a "difficult to find electrical problem" that was beyond the realms of what we should find in performing those electrical troubleshooting steps you all performed, that still would have the machine performing incorrectly.
I was also sincere in my statement that if you needed any assistance I would offer it, why you would belittle this with such a base response as you did, leads me to believe I am speaking to people with a bit of a the same attitude I was initally slapped for.
Sorry I could not attend the National, I would have rather talked face to face to discuss the issues you were having with your bike, or any other issues you seem to have with me on a personal level.
Best of luck, and ride safe.
Offline bbroj
« Reply #37 on: August 13, 2011, 05:20:04 PM »
"it still angers me that she found that necessary, but hey, I'll just consider the source. "
"I did not make the last post with intent to insult, and kept it very congenial"
Really?
COG 9331
