« Reply #2 on: June 11, 2025, 04:07:34 PM »
Brake fluid should be changed every 2 years as it absorbs moisture and clogs up the brake system and the moisture and damge rubber parts. If it has not been changed since 2020 that is likely the problem. A thorough flush and new fluid is what I would try but you likely will need to replace the seals in master and slave cylindars. Good luck!
I was going to post similar. I would first change fluid with flush on both front and rear. It is a good starting point, but I wouldn't hold out hope that it is going to fix a problem where the rear brake pedal goes completely limp.
Also, this isn't likely an ABS problem unless you see an error code on the screen at some point. The computer monitors that pretty regularly and I think performs some forms of self-testing as well. So, OP, I wouldn't jump to that conclusion.
Logged
