Author Topic: F1 Error code 65  (Read 6217 times)
Offline Diablo6v
F1 Error code 65
« on: August 29, 2024, 12:33:40 PM »
Changed my spark plugs and put everything back together. Bike starts backfires and comes up with an F1 error code 65. Anyone know what that is? I can't find it anywhere. I didn't touch any of the battery grounds didn't even disconnect it. So its not the battery or the ground needing to be cleaned.
Offline Freddy
Re: F1 Error code 65
« Reply #1 on: August 29, 2024, 07:29:22 PM »
65
Oil Control
solenoid
valve
– If the oil control solenoid valve fails, valve is
retard position.
65 wouldn't/shouldn't cause a backfire I reckon.  Do you the have coil connectors in correct order?
Are sure it's not 64?
64 Air Switching
Valve
The air switching valve
controls the flow of the
secondary air by opening
and shutting the solenoid
valve.
64 Air Switching
Valve
Air switching valve
malfunction, open wiring or short.
