Author Topic: Admore Light Bar Installation  (Read 53152 times)
Re: Admore Light Bar Installation
« Reply #40 on: May 17, 2016, 03:59:18 PM »
Another full year of working perfectly... knock on wood!
« Reply #41 on: June 01, 2018, 03:19:29 PM »
And two more years of my mounting working perfectly (3 total on new mounting design)... knock on some additional wood.  So it seems like the modified mounting design is certainly a keeper.  So I still highly recommend.
« Last Edit: June 02, 2018, 06:05:25 AM by maxtog »
« Reply #42 on: June 01, 2018, 10:50:30 PM »
Seven years for mine last month, and still only that one LED is out on the left light bar.
« Reply #43 on: June 02, 2018, 06:04:32 AM »
Seven years on mine too, in a month.
I will admit that mine does get some condensation/moisture in it, especially after washing the bike.  But it isn't tons and it doesn't seem to affect it at all.  Their bracket also has a little rust on it.
« Reply #44 on: June 02, 2018, 08:41:17 AM »
...especially after washing the bike.
Huh?  ???   I'm not familiar with that...is that something new?
Is that related to this "washing" you speak of?
« Reply #45 on: June 02, 2018, 07:28:59 PM »
Nah.  It is that thing, like I did today, that gets rid of all the grime and bugs and crap and replaces it with shine and pride!  I even "waxed" it (of course it is not wax, how primitive; but saying "polished" sounds strange) which helps protect it and makes it easier to keep clean.  It also gives me a chance to check everything out and make sure nothing is loose, missing, damaged, whatever.  And clean mirrors and dash makes it more convenient and safe to use, too.
Interestingly, I was missing a bolt that holds the top cover on.  Somehow I must have forgotten to put it back in when I did that "bleeding" of the clutch fluid.  It is just gone.  I scrounged around and found two that were from the rack before I added the helmet locks (which came with longer ones).  It was the right thread and head, but too long, so I just used a tall washer.  Oops.... I said "wash" again..........   :o
« Reply #46 on: June 03, 2018, 12:46:39 AM »
But don't the encrusted bugs and grime sort of cement everthing to the bike so you don't have to worry about things getting loose and flying off? As for damage I always thought the crusty exterior sort of provided a level of impact absorption. I know when new bugs hit the old encrusted bugs that instead of sticking  they just bounce away. Different strokes I guess. Your way sounds like a lot of work. ;D
« Last Edit: June 03, 2018, 08:35:58 AM by fartymarty »
« Reply #47 on: June 03, 2018, 06:30:51 AM »
« Reply #48 on: June 24, 2024, 03:57:00 PM »
Looks like the forum change ATE the original PDF attachment and all the photos.  I am posting it again, now.  Please note this PDF was before I made the slight support modifications later in the thread to take some load off the license plate.
