I had the dealer do both of these things when I took it for the first service, (remove the risers and add the Cee Baileys WS.) My, what I'm sure are very simple questions, are:
-Since I will likely experiment with various WS's as I do with all bikes, and didn't swap this one out, I'm wondering if the back bracket on the WS is attached with an adhesive of some type. I used a 4mm allen to remove the screws and the front bracket came off but the WS was firmly still in place. There was a rubber washer behind bracket on the back and what appeared to be so kind of adhesive so I didn't want to force the WS off.
-For the handlebars, how do you remove the black plastic bolt covers on the six bolts securing them to the bike. I know, lame question, and it seems obvious that it's pop a flat head in and pop them out, but there isn't a good place to get under them and not wanting to ding them all up trying to dig them out should I decide to put the risers back on at some point.
Thanks
