Author Topic: 1986 GPZ1000R Falicon supercrank  (Read 1908 times)
Offline Chrome Megaphone
« on: October 05, 2020, 12:35:03 PM »
If I'm building for HP should I consider?  Falicon no longer reworks crankshafts, what did they do, lightened and neutrally balance?  Currently have ZX10 rods ZZR1100 pistons, GPZ900 cams, going to port the head.
https://www.ebay.com/itm/Falicon-Super-Crank-Crankshaft-1986-1987-Kawasaki-Ninja-GPZ1000-1000R-Motorcycle/164202859838
« Last Edit: October 05, 2020, 01:16:40 PM by Chrome Megaphone »
Re: 1986 GPZ1000R Falicon supercrank
« Reply #1 on: February 07, 2021, 04:54:57 PM »
I have the same parts {I believe}.
I forget which pistons they are, but their .080" oversized as I recall.
The Rods are longer than stock and the pistons have a wrist pin location that matches that rod length.
The pairing pushes the new piston about .020" higher than the top of the OEM piston.
ie; More compression.
I balanced all of my parts, and never got back to doing the build.
The pistons/rods you have are lighter than stock, so they shouldn't add any strain to the crank.
