Author Topic: Wax Your Fork Tubes  (Read 7033 times)
Offline Facewest
Wax Your Fork Tubes
« on: September 10, 2020, 01:11:12 AM »
I have been waxing my fork tubes for a few years.
In addition to my 2016 Concours I have a 2000 Kawasaki ZX-12r. My fork seals started leaking and the rebuilder told me to please start waxing my fork tubes as it will help the seals last a lot longer.
He also told me the plating on the fork tube will last longer too.
I use Eagle 1 Wax AS U Dry because it is a liquid and I don't have to worry about the messy wax paste from normal wax.
You can really feel the difference when you run your fingers along the tube.
Re: Wax Your Fork Tubes
« Reply #1 on: September 10, 2020, 05:13:23 AM »
I have never heard of doing this.  Sounds interesting.  I have been fighting leaks for at least the last year now and have to make sure the tubes are clean all the time (every ride).  This could be an interesting discussion!
« Reply #2 on: September 10, 2020, 08:01:20 AM »
This does sound interesting.
« Reply #3 on: September 10, 2020, 08:17:22 AM »
Interesting idea. Need more discussion.
I think the biggest thing your accomplishing with waxing, is cleaning your fork tubes.
But, the additional smoothness may be good for the fork action because of less stiction?
I assume the wax doesn't stay there very long with seal rub and the oil that gets on the tube? {after it moves thru the seal}
Offline philipintexas
    • Phils Farkels
« Reply #4 on: September 10, 2020, 10:00:20 AM »
For decades I have used silicone lube inside the top dust seal after cleaning. Don’t know if it helps but makes me feel better.
« Reply #5 on: September 10, 2020, 02:25:49 PM »
Indeed.  I can't find much information about doing this (theory, pros, cons, what type of "wax", etc).
It could help seal surface irregularities that will then help prevent dirt/dust/contaminates from sticking.  This would help to keep them clean or at least easier to remove contaminates when actually cleaning.  Or it might contaminate the seals.  I don't know.
« Reply #6 on: September 10, 2020, 07:05:24 PM »
I read on the Internet that giving them a rub down with wax paper also helps.
« Reply #7 on: September 10, 2020, 07:28:38 PM »
Might be a little rough. You could try rear end lube.
« Reply #8 on: September 11, 2020, 02:09:03 PM »
Easy Pinkerbell!!! :o
« Reply #9 on: September 12, 2020, 08:00:47 AM »
I've always waxed the fork tubes. Not because of concern for the seals but because it makes getting the bug guts off so much easier.
Offline bmidd
« Reply #10 on: September 13, 2020, 06:39:08 PM »
I always wipe WD40 on the tubes with a finger after I get finished riding.
« Reply #11 on: September 13, 2020, 07:34:50 PM »
Hopefully your finger, correct?
Offline Cuda
« Reply #12 on: December 02, 2021, 07:36:02 PM »
Was installing LED lights as replacement for parking lights and noticed pitting on tubes, this makes sense now, those pits could ruin a seal quick.
Gods waiting room Naples
2011 Atomic  Silver
« Reply #13 on: December 03, 2021, 02:23:23 AM »
After my recent fork rebuild (75k miles), there was no pitting but the chrome was worn where the tube slides through the bush, not where it slides through the seal. The seals were leaking as they were worn out, not notched or damaged, just worn.
I have since acquired a set of used ZX14(ABS) forks that are away being re-chromed and rebuilt with springs and valving set for my weight.
Once they are done I'll be fitting those as well as the used (3k miles) Ohlins KA109 shock and should have decent suspension. :-)
« Reply #14 on: December 03, 2021, 05:25:13 AM »
But will you wax them?
« Reply #15 on: December 03, 2021, 06:27:55 AM »
Wax sounds like a good idea but what recently started using after two leaks in two years are fork socks, so far so good after three years. They are designed mostly for off road bikes but they work on any fork.
Offline PH14
« Reply #16 on: December 03, 2021, 10:36:14 AM »
Which fork socks are you running, and which size?
I thought about waxing my forks, but I looked, and they aren't hairy.  :finger_fing11:
« Reply #17 on: December 03, 2021, 10:55:02 AM »
LOL, idiot.
Offline PH14
« Reply #18 on: December 03, 2021, 12:59:45 PM »
LOL, idiot.
 :finger_fing11:
Okay, seriously though, which ones do you have, and is there a size I have to choose? I looked quite a while back, but were unsure which ones to get.
Thanks
« Reply #19 on: December 03, 2021, 04:52:48 PM »
I also was wondering if putting some type of collapsible environmental barrier over the exposed tubes would be prudent or helpful.  One downside is that it would hide any leaking (at least for a while, until the fluid runs down to the other parts of the bike).
