Author Topic: Racing  (Read 1023 times)
Offline deuce72
  • 98 Concours
Racing
« on: August 08, 2020, 03:06:20 PM »
I'm having some issue with racing(if that is the correct term) while shifting. Everything at idle and down shifting is fine. As I shift from 1st to 2nd the the rpms jump a little. As I progress into the higher gears with higher rpms it is more pronounced. I'm hoping that there is not something going on with the clutch. Maybe something hung up with the cables?
Thanks
deuce
98 Concours
Re: Racing
« Reply #1 on: August 08, 2020, 04:50:09 PM »
Sounds like bound up or dry cables.
Offline tweeter55
  • Ride Hard...Ride Safe
Re: Racing
« Reply #2 on: August 09, 2020, 07:23:51 PM »
How about the throttle cables?
gpineau
Re: Racing
« Reply #3 on: August 09, 2020, 07:38:37 PM »
could be throttle cables. When does it happen? Between gears ? or after you release the clutch?
Offline deuce72
  • 98 Concours
Re: Racing
« Reply #4 on: August 12, 2020, 05:57:40 PM »
To answer the questions:
It happens when I squeeze the clutch.
I will be taking a look at the throttle cables and giving them a lube for starters. Also, I had a rubber cap crack on one of the vacuum ports and the engine was not running well. To compensate I was turning up the idle so as to not stall at the lights. I think maybe I over did it. Vacuum caps have been replaced and everything is fine but having trouble getting idle to spec.
98 Concours
Offline deuce72
  • 98 Concours
Re: Racing
« Reply #5 on: September 19, 2020, 07:06:38 PM »
Update for those who care.  Lubed the throttle cables, cleaned the carbs and did a valve adjustment and all is well with the concours.
98 Concours
Re: Racing
« Reply #6 on: September 20, 2020, 07:06:26 AM »
I certainly care.  Thanks for letting us know what worked.
