Author Topic: Seat Cover Install Suggestions  (Read 2139 times)
Offline sport rider
« on: January 28, 2020, 08:40:00 AM »
I'm installing a new seat cover on a stock plastic pan.  has anyone done this and what kind of stapler did you use?  I have the usual manual shop stapler, but it does not seem strong enough to fire the staple all the way home.  I'm thinking about getting an electric one, but wanted to know if anyone else had experience with it.  thx!
gpineau
Re: Seat Cover Install Suggestions
« Reply #1 on: January 28, 2020, 01:53:18 PM »
I've tried both the manual and electric, but neither was capable of driving the staples all the way into the plastic.  Once I used needle nose pliers to get them the rest of the way in and another time I used small sheet metal screws.
Next time i need to do this I will use a pneumatic stapler. Like this one.
https://www.amazon.com/Surebonder-9600AK-Pneumatic-Standard-Stapler/dp/B00PK1BMR4/ref=sr_1_5?gclid=CjwKCAiA1L_xBRA2EiwAgcLKA5TFjffqy3WK5yLSzbYEyd5tx8c1lMJtEc-x_uANfUChTDOQgTlqixoC8u8QAvD_BwE&hvadid=409931315412&hvdev=c&hvlocphy=9028883&hvnetw=g&hvpos=1t1&hvqmt=e&hvrand=16152177154195197566&hvtargid=kwd-899967739&hydadcr=1638_11256579&keywords=upholstery%2Bstaple%2Bgun&qid=1580244391&sr=8-5&th=1
gpineau
« Reply #2 on: January 28, 2020, 01:55:34 PM »
Btw, where did you get the seat cover. I am ashamed of the hacked up job I did on my seat. I have a guy wanting $150 to fix it.
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
« Reply #3 on: January 28, 2020, 02:02:27 PM »
It's been a while but I believe I used a manual carpet stable gun.
« Last Edit: January 29, 2020, 12:06:53 PM by George R. Young »
« Reply #4 on: January 29, 2020, 02:32:36 AM »
Manual and electric staple guns are not man enough. Pneumatic is the only way to get the staples fully into the plastic seat base.
Sometimes you can use a manual/electric to place them, and then manually hammer the staples home, but it's hard work and you will end up bending the staples more often than not.
Offline sport rider
« Reply #5 on: January 29, 2020, 08:39:12 AM »
Offline sport rider
« Reply #6 on: January 29, 2020, 08:40:09 AM »
thanks for the input everyone.  seems y'all are thinking along the same lines I was.
« Reply #7 on: January 29, 2020, 08:52:07 AM »
I suggest you use the shortest staples possible.
  Shorter are take less force to drive into the plastic, less likely to bend, and the sharp end doesn't go thru the plastic into the seat cover and yer leg/ butt..  :thumbs:
Offline sport rider
« Reply #8 on: February 01, 2020, 03:14:40 PM »
the pneumatic stapler worked like a charm.  generally used 1/4 inch staples, but used a few 3/8s for some of the thicker folds.
The pic is of the seat I ordered in the link above.  for a cheap OEM replacement, it's a fine alternative.  the guy sewed in some additional padding. so it softer to sit on.  That may be counter to a good seat though as firm usually does better for long hauls.  YMMV
« Reply #9 on: February 02, 2020, 08:56:02 AM »
Dave, you know that I really hate to admit that you did something right. :yikes:
But,, "that looks good"!    :thumbs: :thumbs:
Offline sport rider
« Reply #10 on: February 02, 2020, 09:18:59 AM »
 :rotflmao: :rotflmao: :rotflmao: :rotflmao:
gpineau
« Reply #11 on: February 03, 2020, 09:38:42 PM »
That looks very much like the seat cover I ordered.
You got that on ebay right?
https://www.ebay.com/itm/KAWASAKI-ZG1000-Concours-1994-2006-Custom-Hand-Made-Motorcycle-Seat-Cover/222229498729?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I haven't got mine yet. My seat has been cut off about the same as yours. I am hoping I can add something to it so it is a little longer.
Yours is looking really nice. Excellent job in stapling  it down.  I guess I have an excuse for a pneumatic stapler now....! ;D
gpineau
« Reply #12 on: February 03, 2020, 09:40:25 PM »
BTW, that little Flash Gordon thing behind your seat. Did you make that? how is is constructed?
« Last Edit: February 03, 2020, 10:34:11 PM by gpineau »
Offline sport rider
« Reply #13 on: February 04, 2020, 07:32:52 AM »
if you are referring to the cowl on the back, yes, that's custom.  we cut the front and rear semi-circular panels first and got the angle I wanted.  then we just cut some flat steel and wrapped it over and tacked it in.  then a bit of grinding to clean up the corners.  it still needs finish welding and work to make it "perfect".  I just threw this paint on it rather than leaving it in primer.  prior to that, we built the base frame.  picture here.
Offline Nosmo
« Reply #14 on: February 08, 2020, 11:55:19 AM »
I have a Porter-Cable pneumatic and it will staple anything to anything.
https://www.homedepot.com/p/Porter-Cable-Pneumatic-18-Gauge-3-8-in-Crown-Stapler-TS056/204460975
Offline deuce72
  • 98 Concours
« Reply #15 on: March 03, 2020, 08:54:08 AM »
Yep, same issue for me with the manual gun, not enough power to penetrate the plastic. For those who used the pneumatic staple guns, what was your operating psi? Someone mentioned that you do not want it too much power either.
Thanks
deuce
98 Concours
Offline sport rider
« Reply #16 on: March 03, 2020, 10:41:50 AM »
I have a relatively small HF compressor.  no idea how accurate the gauges are.  I had mine at about 80 and there were very few staples that didn't seat well.
gpineau
« Reply #17 on: March 03, 2020, 11:12:43 AM »
I cheated. I bought the seat cover on Ebay and took it to an upholstery shop and let them put it on for me.  They also smoothed out the rough foam the previous owner used a kitchen knife on.
Offline sport rider
« Reply #18 on: March 03, 2020, 12:43:13 PM »
Yeah, but I have the luxury of knowing mine looks home made.   :banana :banana :banana
Offline RFH87_Connie
« Reply #19 on: March 24, 2020, 12:29:02 PM »
I bought a Sargent brand OEM style cover a few years back and put it on with a manual stapler using 1/4" staples.  I might have used a few 3/8" or 5/16" staples here and there.  I did use a small finish hammer on a few staples to sink them good.  I also used a hefty bag to cover the seat foam first.  Otherwise, it worked fine and nothing has popped up.  Been doing it this way since motocross bikes in the 70's.
