Author Topic: First (and probably last) Valve Adjustment  (Read 33459 times)
Re: First Valve Adjustment / TB Sync
« Reply #40 on: November 02, 2019, 07:18:37 AM »
JB Weld is a good product.  I would think it would hold up fine.
It is strong, for sure.  But at least for the panel crack, I am concerned it won't deal with flex.  Time will tell!
I was going through the maintenance schedule again.  I just can't believe they actually think we should replace the spark plugs every 7,500 miles!  Can't wait to see what state mine are in... perhaps today...
« Reply #41 on: November 02, 2019, 03:38:03 PM »
Today I used my friend's contraption/bushing/thing to reface the broken bolt in the engine mount.  Then bought some new bits and drilled through the bolt with a 5/16".  Took a long time.  Not sure how true or square it is.  Now I have to wait for him to come and try to remove what is left of the bolt.
It wasn't true/square.  Used heat and an extractor without success.  Drilled out larger and then pushed out pieces what was left of it (out the back), which took threads with it.  Photos of largest chunk attached.  So we will have to use an insert.  I expected as much.
Finished the valve adjustment.  So now clearances are as follows:
1in .006/.008 2in .006/.006 3in .007/.007 4in .008/.007
1ex .009/.009 2ex .009/.009 3ex .008/.008 4ex .008/.008
Replaced spark plugs.  One was slightly overgapped.  None looked all that bad, but all replaced with new.  Changed all the gaskets, put back on cam over, put back exhaust cam sensor with oversized O ring.  Changed oil, cleaned throttle bodies.  Tons of reassembly left to do, some day, so it can be tested.
Noticed the right fan has a little grinding noise when free-spun, the left one doesn't do that.
Offline strum
« Reply #42 on: November 02, 2019, 06:52:56 PM »
Am I wrong to say most of those intakes are too loose?
Valve Clearance Standard:
0.19 ∼ 0.24 mm (0.0075 ∼ 0.0094 in.)Exhaust
0.12 ∼ 0.17 mm (0.0047 ∼ 0.0067 in.)Inlet
« Reply #43 on: November 02, 2019, 09:57:01 PM »
No.  They are, indeed, on the loose side, but that was intentional because they will [almost always] tighten over time.  You will find most people will adjust them to be on the loose side.  We do admit that the .008 was not intentional nor ideal (we were targeting 0.006 - 0.007), but we couldn't do much else without having to go through a lot of work again and decided it was good enough.  It was a tight 0.008, though (so probably more like 0.0075).
« Reply #44 on: November 03, 2019, 09:25:32 AM »
Was that grinding noise with the fan removed from the radiator or attached? I only ask because you don't want this: http://forum.cog-online.org/rallies-rides-and-events/radiator-patch-at-national/
Offline strum
« Reply #45 on: November 03, 2019, 11:08:55 AM »
 I agree its good to adjust on the high end of spec but to go out of spec to me is a no go.  I think the ex is most subject to tighten than the Intakes. I mean its youre bike but after all you been through I say go back in and get em closer. I know its a pain but you wont be back in some time if ever so this is the time to get it right.
« Reply #46 on: November 03, 2019, 01:24:01 PM »
Most people, even tho they are very mechanically inclined, simply don't use measurement tools that give finite readings to an ideal precision; case in point
using metric feeler stock, or feeler blades with 3 decimal place precision, and calipers or micrometers with the same 3 decimal place precision, can only "assume" what they read out is "real"; then they haave to base the readings on "did it feel tight, or loose"...
I've said before here, that an economical micrometer, delinated to 4 decimal places (.xxxx"), when used correctly, actually can offer great amounts of clarity on the actual dimension. Combined with again, very economical precision "feeler blades/strips", also combined with being "stacked, and measured to verify", give the same results in judging clearances...
It takes the guesswork about "is this dimension .0002" or .0008" off" from the nominal 3 place dimension.
Individual feelers and also the micrometer which I purchased from McMaster-Carr, only totaled me about $50, and as in my industry I could have the tools verified thru our calibration people.
Then, when happy I am working with good tools, adding in the ability to measure and swap the individual buckets, and seeing the span of deviation on those particular parts, the ability to swap around those along with my shim map, gave me extreme flexibility, and minimal shim purchase expense; while still resulting in meticulous readings.
Opening up the engine, and going thru this does take time, and an amount of patiance and skill.... but in the end, I don't really want to say "it's good enough" when I know the measurements may be "iffy" on my bike.
I'm sure what Max came out with is fine, and will not result in a catastrophic failure; Haroldo proved that it's all possible, with some essence of magic.
Congrats on the job Max.
« Reply #47 on: November 03, 2019, 03:54:26 PM »
Had that very thing happen with a friend of mine's BMW many years ago.  We used JB Weld to fix it.  It lasted 5 years and then failed when an old lady T-boned him and the bike.
« Reply #48 on: November 03, 2019, 08:37:20 PM »
With it attached, spun by hand.  It is not touching anything.  Sounds like the bearings are a bit wonky.  I don't recall reading anything about this before, and searched the forums with no matches.  It could be normal for that fan, I don't know (since I have never touched it before).  I do need to apply power to it as a test to see what that sounds like, but haven't gotten to it yet.
« Reply #49 on: November 03, 2019, 08:50:13 PM »
Well, that doesn't match the experience with this bike.  Of course, I have a sample size of exactly 1, but look at how incredibly far out of spec my intakes were compared to the exhaust [assuming from the factory they were all dead-on-center] .  Almost all the exhaust were only 0.0005 out of spec, but most of the intakes were 0.0027 out of spec (540% more out of spec than the exhaust)!  Of course "Please remember that past performance may not be indicative of future results."
« Reply #50 on: November 03, 2019, 08:53:53 PM »
I'm sure what Max came out with is fine, and will not result in a catastrophic failure[...]Congrats on the job Max.
Don't congratulate yet.  It could be weeks before this nightmare ends... longer if something goes wrong.  Still not sure we can ever get it all back together again [correctly].
« Reply #51 on: November 09, 2019, 03:24:00 PM »
Today we put in a "Time Sert" thread insert which repaired the right engine mount and reattached the canyon cage using a new bolt.  Reassembled the throttle bodies, velocity stacks, plugged everything back in, reattached the radiator, throttle, engine stays, air box covers.  It is close to testing.
After 4 hour, my friend left and I continued connecting things for another hour until I hit the fairing stays and I can't figure them out, so I will wait for help.
« Reply #52 on: November 09, 2019, 04:26:14 PM »
I'll dig thru my photos, and post if it would help, using the Kaw parts Microfiche may help also in seeing which is which, and what bolts go where...
Prolly tomorrow, during halftime of the game.
 :'( 8) ;)
« Reply #53 on: November 09, 2019, 11:46:02 PM »
That would be helpful.  The photos in the manual are practically useless- they are so small and bleak.  If I just had a few decent photos of the two sides of the bike with just the covers off.  I am kicking myself for not doing so.
Damn it is cold suddenly.
« Reply #54 on: November 10, 2019, 11:02:14 AM »
Never mind.  I actually figured it out.  FINALLY.  So all that is now done, too, plus I put the tank back on.  It is ready to test.
« Reply #55 on: November 10, 2019, 11:32:58 AM »
fingers crossed emoticon goes here.  :thumbs:
« Reply #56 on: November 10, 2019, 01:51:17 PM »
It works!!!!!!!
 :)  :D  :)  :D  ;D  :D  :)
Had my friend on the phone and he gave the green light to try it.  First attempt failed with flashing fuel level and no sound of fuel pump.  Yep, forgot those two connectors.  After that, started after the third try!  Then it starts instantly each time (and with no familiar timing chain rattle, either).  Made a hell of a lot of smoke, scared me, but friend said it was just oil.  So worked on filling and filling the cooling system with distilled water.  Then let it run until fans cycled twice.  Now waiting for it to cool down so I can drain it and replace with antifreeze mix.
As much as I wanted to test the TB sync, it isn't going to happen.  Neither of us have the time or patience or tools to do it.  Oh well.
I am going to replace the final drive oil now.  Then farings and rubber crap nightmare is after that.
« Reply #57 on: November 11, 2019, 06:45:12 PM »
I spent hours putting on fairings, save one (the middle left) because I am concerned I might need to add more coolant.  It only accepted 2.5qt, same as when I filled for flushing.  I don't know if that is normal or not.
So I decided to take a test drive tonight (with that one fairing off)....
WOW
What a difference!!!  All the low-end problems are now GONE.  It is smooth as glass- especially noticeable with launching and downshifting to a stop.  I knew it was bad, but the contrast is amazing.  It is so easy to drive now.  I only rode for 30 min, haven't even eaten dinner yet, but I really wanted to keep going.
No change in coolant level in reserve/overflow tank.  Still exactly on "full".  During the ride (ambient 55F) I was always at 2 bars (of 6) when moving and 3 bars when stopped for a short while.  That is normal for this weather.  At home, I let it idle in garage, and it crept to 4 bars, then after a while the fans started cycling, keeping it at 4 bars.
« Reply #58 on: November 11, 2019, 10:37:56 PM »
Congrats max'!  :thumbs: :chugbeer:
I guess I better get that overcoat and some heated gear on, Hell is about to freeze over.  :P
« Reply #59 on: November 12, 2019, 07:33:13 AM »
Well done Max!    :chugbeer:
