Author Topic: Delkevic full exhaust  (Read 9220 times)
Re: Delkevic full exhaust
« Reply #20 on: September 03, 2019, 07:03:05 AM »
In the roll on, his bike was flashed and has a slip on?
Yours has the Delk full system, but is not flashed?
Offline CDII
« Reply #21 on: September 04, 2019, 08:41:08 AM »
That's right Ted mine has no flash yet just full Delkevic system. His has Delk 14" slip on.
Thanks for the reminder Maxtog.
His bike is 625 w/half tank of fuel, mine is 680 + tools I didn't weigh.
He is 165, I'm 180  :-\. That's more than 70lbs in his favor. Hmm
Can't wait for that flash!
« Reply #22 on: September 04, 2019, 03:32:17 PM »
Oh, I didn't know you had no flash at all.  That will seriously hurt performance.
Thanks for the reminder Maxtog.  His bike is 625 w/half tank of fuel, mine is 680 + tools I didn't weigh. He is 165, I'm 180  :-\. That's more than 70lbs in his favor. Hmm
That will matter.
That will matter a LOT.  Matter much much more than anything else you have, will, or can do.  I wish I could see the smile on your face after...
Offline CDII
« Reply #23 on: September 04, 2019, 07:06:20 PM »
Yes Maxtog
I know Steve's tune made a huge difference.
My newest to me 09 is just as fast from 5k up with just the full exhaust.
I'm sure the tune will help pick more bottom end too.
« Reply #24 on: September 04, 2019, 07:49:55 PM »
Steve has modified a Full Area P Flash for the Delk. full system.
Several that bought the Delk. System have installed it in their ECU..
Early reports are "very" good...
Offline Daytona_Mike
« Reply #25 on: September 05, 2019, 03:15:56 PM »
I have the new Premium Full AreaP flash from Steve.  You cannot compare that to his previous flashes or even his previous flash that was on my bike.
 It is THAT much better. Holy mackerel. I thought there was no way this bike could be faster.... well.. IT IS~~!!
« Reply #26 on: September 05, 2019, 03:25:04 PM »
I have the new Premium Full AreaP flash from Steve.  You cannot compare that to his previous flashes.  It is THAT much better. Holy mackerel. I thought there was no way this bike could be faster.... well.. IT IS~~!!
Since (like most motorcycles) the Concours has no air mass sensor (and no active O2 sensor in most cases), it depends completely on maps for fuel metering.  These maps has to make lots of assumptions about how much air is going into the engine under all kinds of conditions.  At the high end of the RPM scale (maybe 7K+), there will be a potential performance difference between the stock exhaust and a full exhaust system replacement (and especially combined with TB replacement).  That can't be dialed into the "stock" reflash he offers, because it would hurt stock performance.  So, yeah, if you slap on an AreaP, it makes sense to get a flash specifically designed for it.  (It can also correct some of the loss of power on the low end, too, that I would expect from putting on an AreaP; it can't correct it all, because it will lose some lower-end power, regardless.  But you don't want to make things worse than necessary).
It does make one wonder why we don't have mass air flow sensors.  They aren't THAT expensive or big anymore, and makes things so much easier and more accurate.  Oh well.
Offline CDII
« Reply #27 on: September 05, 2019, 08:42:47 PM »
Thanks guys for all your replies.
I love the big block, and it can get even better!
Offline CDII
« Reply #28 on: September 05, 2019, 08:45:47 PM »
Is anyone running the ZX14 throttle bodies with the full Delkevic system?
Does the flash cover any additional bottom end torque/hp loss?
Thanks!
« Reply #29 on: September 06, 2019, 12:49:36 AM »
Yes.  Several people have because I have seen such postings in the past.
That question doesn't relate to your first.  I can answer in theory (which is supported by facts, like physics and dyno runs), and did so in my previous post.  Yes, a reflash that is designed specifically for a "full exhaust" should be able to help some compared to a reflash not designed for a "full exhaust", but it will not recover all the lost low-end torque/hp.  It is just a matter of physics :)
The Concours has more low-end power than a ZX-14 and less high-end power.  Same displacement engine, different design parameters.  Smaller exhaust/TB and different/variable cams allowed the Concours to be tuned to deliver more power in the "comfort" areas where "touring" users are more likely to use it and appreciate it.  The opposite for the ZX-14, where the tuning (exhaust/TB different cam and lack of variable valves) shifted the power to the higher-end, raising the power (and, thus, maximum HP) in the range more appropriate for that type of rider.
The more the Concours engine setup is changed to be like the ZX14, the more loss of low-end power and the more gain in high-end power.  It is a trade-off.  Power can't be invented out of thin air- it is being shifted from one place to another.... aside from the fact that reflashing a stock Concours unlocks the full power it has because it undoes most of the things Kawasaki did for noise and emissions control (so that is kinda "free power").
Knowing the peak HP on a vehicle (which most people obsess over), which is a single point, doesn't tell the story of everything that came before it, as you can see in the attached graph.  So.... is the ZX-14 (reflashed or not) more "powerful" than the reflashed (otherwise stock) Concours?  No.  Is it "faster"?  In few cases, no.  In most cases, yes.  In some cases very much so.  The ZX-14 is lighter (it has fewer features and storage and convenience), is more aerodynamic (making it more uncomfortable), is geared a little lower (which is better for getting the the higher RPM sooner, but not good for keeping in the comfort zone), and has a chain drive which reduces final drive loss (making it require more maintenance).  The cam profile and lack of variable valves makes it less responsive and smooth, less fuel efficient, and louder, in the relaxed-riding RPM range.  It also makes it, overall, less reliable.  Trade-offs.
« Reply #30 on: September 06, 2019, 07:38:24 AM »
There are 2 ride reports in this discussion by HR. Well written.
They will give you a good idea of what to expect with the Delk. System and Steve's modified Area P Flash.
http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/pro-cons-of-de-catting-exhaust/msg676950/#msg676950
Offline CDII
« Reply #31 on: September 08, 2019, 08:38:12 PM »
Thanks Ted
Exactly what I expected with larger diameter primary tubes. It moves the torque curve up higher in the revs.
The tune I think will cover that and have great top end, of course with all the smoothness of Steve's flashes.  :goodpost:
