Kawasaki Concours Forum
Welcome,
Guest
. Please
login
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
The C10, aka Kawasaki Concours - The Original
The Bike - C10
(Moderator:
George R. Young
Shifting thoughts
« previous
next »
Print
Go Down
Author
Topic: Shifting thoughts (Read 1690 times)
deuce72
Jr. Member
Country:
98 Concours
Shifting thoughts
on:
July 30, 2019, 08:14:48 PM »
Instead of finding threads I will pose this question. What are the signs of shift linkage going bad. And is there anything preventative to date that I can do?
98 C10 with 62XXX as of this post.
Thanks!
deuce
Logged
98 Concours
DC Concours
Arena
Full Member
Country:
2001 Concours, ~35K miles
Re: Shifting thoughts
Reply #1 on:
July 30, 2019, 09:59:07 PM »
um. What symptoms are you trying to remedy?
Usually shifting is generally sloopy or you will feel a miss from 1 to 2. But linkages don't go bad that often. So you need more diagnosis and describe exactly what you feel. It could also be your transmission!
I don't think these linkages can be adjusted and I believe need replacing. Your bike is middle aged (or approaching end of life if you haven't cared for it) so if linkage is bad look into Tcro's linkage as an upgrade (if he still makes them). People seem to like them.
Logged
billhook
Arena
Jr. Member
Reply #2 on:
July 31, 2019, 11:18:49 AM »
As of 2 years ago, Tcro is no longer making the upgraded linkage.
http://www.zggtr.org/index.php?topic=67.0
Logged
Nosmo
Full Member
Country:
"We're all in this together." - Red Green
Reply #3 on:
July 31, 2019, 06:09:04 PM »
The C-10 linkage is adjustable. There is a threaded rod between the pedal and the shaft coming out of the transmission. Loosen the lock-nuts at the ends and turn the threaded rod to lengthen/shorten as needed.
Logged
A life undreamed is a waste. A dream unlived is a sin.
deuce72
Jr. Member
Country:
98 Concours
Reply #4 on:
July 31, 2019, 06:59:58 PM »
So far nothing seems to be of an issue. Just wanting to stay ahead of potential maintenance.
Thanks for the adjustment tip, I will be tweaking the shifter. Yeah, too bad about T-cro no longer in production, sounds like it was a great product.
Logged
98 Concours
DC Concours
Arena
Full Member
Country:
Reply #5 on:
July 31, 2019, 09:31:21 PM »
I think that adjustment is for your boot fit. Not if you miss gears.
Logged
Daytona_Mike
Arena
Full Member
Country:
Reply #6 on:
August 01, 2019, 02:40:52 PM »
A lot of slop / play in the stock linkages. Maybe some one has the plans for the upgrade Tcro did. I have it and makes a big difference. Look at the pictures and maybe try and copy it.
Logged
Print
Go Up
« previous
next »
The Bike - C10
(Moderator:
George R. Young
Shifting thoughts
