Author Topic: Screw near the side of my 3 week old tire... possible to plug?  (Read 32323 times)
Re: Screw near the side of my 3 week old tire... possible to plug?
« Reply #40 on: April 02, 2019, 05:34:37 AM »
I'm guessing of course, but I suspect a motorcycle.
Offline Michelle
  • Saving the chubby unicorns
« Reply #41 on: April 02, 2019, 07:09:14 AM »
Not just any motorcycle. A Neutron Silver one.
Welcome to the forum, Michelle. What are you riding?
Thanks Gary. Its in my sig.  ;D
Glitter White 2010 1400GTR
Windsor Green 1997 GTR1000
« Reply #42 on: April 02, 2019, 07:27:03 AM »
Of course, it is the fastest colour.
Offline STC14JIM
« Reply #43 on: April 02, 2019, 01:45:02 PM »
Old glue is still good, and I bought some quality worm plugs and a small tube of glue in a kit, just for S&G's.
« Reply #44 on: April 02, 2019, 04:16:59 PM »
:battle:
:doh:
« Reply #45 on: April 02, 2019, 04:47:58 PM »
LOL
« Reply #46 on: April 04, 2019, 03:50:12 AM »
Is Michelle a chick or a dewd? I'll assume a dude, the way they pimpslapped Pinkerbell. 8)
I never use the glue, but always carry plugs and a pump. I've seen plugs leak, but I was in the auto tire industry for a couple of years. 8)
Offline Michelle
« Reply #47 on: April 04, 2019, 04:44:52 AM »
I just gotta say, the only dudes I ever met called Michelle, are French. And they spell it differently.  ;)
You should never assume ...
The only time I've ever had a plug leak was when it was more of a cut than a simple puncture.
« Reply #48 on: April 04, 2019, 06:07:09 AM »
I dig Chicks that ride. I think all guys do  8)
Offline tjhess74
« Reply #49 on: April 10, 2019, 08:48:21 PM »
As requested, my plugging 'technique'...
I get my rope set in the t-handle. I then get the reaming t-handle (the one with the sharp pointy end) in one hand and a pair of pliers in the other. I pull said offensive item out of the tire and immediately insert the reamer to prevent losing too much air. I'll ream the hole by going in and out and also rotating simultaneously a few times. When that is finished, I'll remove the reamer and immediately start inserting the plug t-handle. It usually takes some gumption to get it in there. I'll insert until about an inch, inch and a half of rope end is sticking out, then I'll remove the handle. Lastly, I'll use a razor blade to cut the rope ends off about an 1/8-1/4 of an inch above the tread. Then I ride as if nothing happened.
Michelle, welcome! I've been to Australia and absolutely loved every minute of it!
The 'other' forum evicted me!
