Author Topic: The Kilogram....Huh?  (Read 20938 times)
Re: The Kilogram....Huh?
« Reply #20 on: November 25, 2018, 08:23:26 PM »
Whatever happened to Marty? He seemed so interested in this subject......?
He is off building that balance...
Offline Hooligan
  • Country: za
  • never assume, get the facts
« Reply #21 on: November 26, 2018, 12:27:13 AM »
Now what did us South African do wrong to get pulled into the conversation here....? But seeing you brought it up, lets carry on.....
So, my father's side of the family is a mixture of Irish (Butler) and Dutch (de Koning) origins, while my mother's side is French (du Plesis) and Dutch (le Roes) origins.
I'm 12th generation South African, as a family member went and did research on the French side of the family tree (du Plesis), all the way back to France in the year 1658.
Now, I have 2x questions for you.....
1) What does that mixture of origins make me?
2) If you are travelling at 60Km/H, how long must the rope be to tie the canoe to the jetty, before drinking a liter the water?
Or I could give you a hard time in reverse!
One could be Xth generation white (historically European at some point), South African and move here- and be African-American.  Or one could be an Xth generation black American who moves to South Africa (American-South African?) and marries a white European-South-African and their children move back to the USA who are thus both black and white South-African-African-European-African-South-African-American?
I love political correctness, because it gives me the wonderful opportunity to throw out how hypocritical it all is.  I harassed someone just a few days ago who said, in the same sentence, "African-American", "Asian-American" and then "White", by asking a return question using the terms "Black", "Yellow" and then "European-American."
Just so just say "a black void" and be done with it :)
2012 K1600GT
2009 ZX14
« Reply #22 on: November 26, 2018, 09:21:43 AM »
2) If you are traveling at 60Km/H, how long must the rope be to tie the canoe to the jetty, before drinking a liter the water?
1) I'd just go with Dutch and let the rest of your genetic heritage go in most situations where the subject comes up. However, if more detail is really needed, then I'd get some genetic
testing done to determine your true origins. Many have found out that some mistakes and/or fabrication were given in the oral history of their ancestral makeup. Some have been arrested
as well, so make sure your DNA isn't somewhere it shouldn't be, before you get sampled.
2) The rope needs to be the same length as it was before drinking the liter of water (this calculation does not take into account tidal fluctuation since time and date, nor jetty coordinates were not specified in the original scenario), and if you're only going 60km/H then your C14 must be in the shop and you're riding a borrowed typical V-twin cruiser?
 :rotflmao: :rotflmao: :rotflmao: :rotflmao:
I was hoping for a 3rd grade explanation of whether a gram is now based on 1/1000 of a Kilogram as measured on a Kimble balance or is it still defined by the weight of one cc of water @4 degrees Celsius. If there was an answer to that posted already, it flew right over me. If it is still based on the one cc of water formula, I don't see how we've made as much progress as we could have in this new development.
HA!  :rotflmao: No, my level of interest isn't that high.  ;D
« Reply #23 on: November 26, 2018, 01:40:18 PM »
A gram is a man- made amount of a fundamental unit, which is mass. But mass has no actual units so the gram is simply assigned to it by us, as the meter was assigned to the fundamental unit length. Now that two completely 'made up' things cross, the cc and a gram of water, is by design when making these imaginary units in the first place and they are very handy for general calculations but still, none of them are linked to anything fundamental or effectively, "real".
There are seven fundamental units or basic units. All others are derived, compounded (such as MPH which is length divided by time, two fundamental units) or some completely man made 'measurement' that are not fundamental or relatable to anything fundamental. The fundamental units are these:
Length
Mass
Brightness (candela)
Current (ampere)
Temperature
Mole
Time
Then there are the four fundamental forces known and they are:
Electromagnetism
Gravity
The Strong force (atomic level only)
The Weak force (atomic level only)
A cubic centimeter of water is a derived unit, consisting of length X length X length. A volume of water measured in any way NOT based on fundamental units is simply a man made 'unit', created so either 1) we can get a handle on something easily- we buy gasoline in gallons, easy and handy but meaningless in the physics world or 2) some link such as one gram is one cubic centimeter of water at a temperature, which is merely man- made units designed to align volume to mass to length or similar.
The Kibble balance has allowed us to define a kilogram by comparing it directly with a fundamental force, which means that the man- made UNIT of a fundamental measurement can now be defined by another man- made UNIT of a different fundamental force. That plus the fact that we can readily only measure one of them (force, not mass) so we can now quantify mass in the physics world.
Or at least that is how it works in my corner of the universe..... I think. :-)
<snip>
« Reply #24 on: November 26, 2018, 02:50:15 PM »
If something weighs # units, or is X units long, or is X degrees temp, or is X bright, etc, but nobody is there to measure it, does it really?
« Reply #25 on: November 26, 2018, 03:32:11 PM »
Just don't go putting cats into boxes....
Offline Poseidon
« Reply #26 on: November 26, 2018, 08:03:53 PM »
And if you do, shake it up really good!  :rotflmao:
2017 Concours 14
2016 Victory Magnum
2013 M109R
« Reply #27 on: November 27, 2018, 09:28:55 AM »
Length
Mass
Current (ampere)
Temperature
Mole
Time
Electromagnetism
Gravity
Thanks, I think. Well OK, that was very informative.
 However I still had to read between the lines to guess that a gram is no longer the weight of 1 cc of water at 4 degrees C, but is now 1/1000 of a kilogram as measured by a Kimble balance. Still a guess however. Since I still haven't built my Kimble balance, I think I'll go get a box of cats to shake up and see if I get better results.
Offline Poseidon
« Reply #28 on: November 27, 2018, 12:37:28 PM »
2017 Concours 14
2016 Victory Magnum
2013 M109R
« Reply #29 on: November 27, 2018, 01:57:08 PM »
The gram was never based on any volume measurement of water. At one time, it was based on 1/1000 th of that 'magic' block sitting at NIST (I still think of it as the Bureau of Weights and Measures, which is probably how you think of it also- same agency although expanded in function).
The meter is arbritrary also: it was originally one ten- millionth of the distance from the equator to the north pole. Pretty random, eh?
Watch out for the 'cat stuff' though, just like the arrow example (if it takes 1/2 of the time for an arrow to travel 1/2 way to its target, and 3/4 of the time for it to get 3/4 of that distance..... then it holds that as the distance can be divided infinitely, so too can the arrow's displacement.... therefore, the arrow will never reach its target. Any arrow, under any circumstances). All horrible examples of sound science either miss- applied or simply used in an example or way that they do not work. Basically, mental masturbation. Be especially wary of anything that uses Heisenberg's 'uncertainty principle'; a very real and sound piece of science.... when it is applied to the uncertainty of knowing both an object's exact position and exact velocity at the same time. Otherwise, it is generally simply misapplied such as to be not only useless but misleading in that someone is actually saying (or writing) something useful.
Previously I had written: "A gram is a man- made amount of a fundamental unit, which is mass. But mass has no actual units so the gram is simply assigned to it by us, as the meter was assigned to the fundamental unit length. Now that two completely 'made up' things cross, the cc and a gram of water, is by design when making these imaginary units in the first place and they are very handy for general calculations but still, none of them are linked to anything fundamental or effectively, "real". "
« Reply #30 on: November 27, 2018, 02:41:18 PM »
Now you've gone all calculus on us. I think  ???
"If Achilles is to run from point A to B, he must first travel half the distance, then half again, and so on. Taking the distance from A to B as one, the distance Achilles must travel is the series 1/2 + 1/4 + 1/8...... Because there is an infinity of terms in this series, Achilles can never reach his goal."
« Reply #31 on: November 27, 2018, 03:39:12 PM »
The ancient Greeks never <quite> got to calculus though they did get 'close enough' IMO. And yes, the arrow will never reach its target because there are infinite 'sections' of distance it must travel is the basis of the concept of limits and asymptotic lines: places one cannot get to but they would be the correct answer if one could go there. But again, when applied to things like moving objects and trying to use these mathematical concepts where they do not belong or apply is, again, mental masturbation IMO.
y = 1/x   As x tends toward infinity (works the other way too, as x tends toward zero), what happens to y. The classic example of limits and asymptopes. You cannot divide by infinity but the closer you get, as x gets bigger, the closer y gets to zero. Hence the limit of the function is zero- a place you cannot get to but you are 'tending toward' that value. And so y 'tends' toward zero. The concept simply does not apply to a moving object and the travel over distance.
But the world is full of miss- applications like that. I always thought Schrödinger's cat was ridiculous, as I think modern quantum physics having electrons disappear and reappear randomly is too.
« Reply #32 on: November 28, 2018, 10:58:13 AM »
OK, I think that is where I made my major mistake. I went back and reread, and they use weathermanperson speak. (I.e. "chance of"; "likelihood of"; "trending towards"; "models show" )
The gram takes inspiration from the density of water: It’s roughly equal to the mass of 1 cubic centimeter of water held at 4°C.
Quote from: Wilkipedia
Originally defined as "the absolute weight of a volume of pure water equal to the cube of the hundredth part of a metre [1 cm3], and at the temperature of melting ice"[2] (later at 4 °C, the temperature of maximum density of water). However, in a reversal of reference and defined units, a gram is now defined as one thousandth of the SI base unit, the kilogram, or 1×10−3 kg, which itself is now defined by the International Bureau of Weights and Measures, not in terms of grams, but by "the amount of electricity needed to counteract its force"[3]
I'm not sure why I started this thread, but at least it got to page three...
....is, again, mental masturbation IMO.
Agreed. ;D (even though that quote was about something else and not this thread as a whole, it still applies IMO)
« Reply #33 on: November 28, 2018, 03:09:11 PM »
Well, it seemed to me that you started this thread because you were curious about both the Kibble balance but especially about how, why and how accurately mass (the gram, the kilogram) was defined / determined / compared in the first place. I took a look, admittedly a skim at first, of the article at the link you posted and conversed about it.
Of course any serious discussion of science needs an injection of amusement so I did my best there...... but it seems to have bounced off. Oh well, off to the next discussion.
I'm not sure why I started this thread, but at least it got to page three... Agreed. ;D (even though that quote was about something else and not this thread as a whole, it still applies IMO)
« Reply #34 on: November 28, 2018, 03:20:22 PM »
see what you started....
and it's just the beginning of the snow season......
by spring, everyone will have gone off the deep end....
see I told you to go buy a Royale with Cheese... and stay away from Burger King
« Reply #35 on: November 29, 2018, 08:01:20 AM »
Hey, I chuckled! You just couldn't hear it over the internet because of all the background noise left over from the big bang....or is that someone's baby blue Indian idling?
