Author Topic: How long before my rear shock needs a rebuild?  (Read 1783 times)
Offline katata1100
« on: November 05, 2018, 12:49:43 PM »
I have seen some sources on the net cite 5 years, others 20K miles. How good is the rear shock on these bikes? Can anyone give some guidelines on them like how many miles and/or years before you should rebuild or replace? I got 34K on my '11 with mostly slabbing miles.
Re: How long before my rear shock needs a rebuild?
« Reply #1 on: November 05, 2018, 01:09:47 PM »
I replaced my rear shock at 108,000 miles. Not because I noticed any problems but because I had a 20% discount certificate for an Ohlins won at a rally. There was some improvement with the Ohlins but not drastic.
« Reply #2 on: November 05, 2018, 03:21:51 PM »
I would be "shocked" (pun intended) if it needed rebuilding as such low intervals.
Offline katata1100
« Reply #3 on: November 05, 2018, 06:35:35 PM »
Fwiw, my ‘91 Suzuki 1100 has only 24k miles but the shock feels dead and I can see a little oil on the end of the rod- I’m fixing the bike up and will send the shock out for a rebuild
Offline Cuda
« Reply #4 on: November 06, 2018, 04:30:09 AM »
That's 27 years :o
Ya think the rubber has degraded any?
Gods waiting room Naples
2011 Atomic  Silver
Offline katata1100
« Reply #5 on: November 06, 2018, 11:13:28 AM »
Which rubber? They no longer make radial tires for its 16" hoops, I have a set of Avon Azzaro radials with 75% tread left, but they are ten years old, they feel as hard as wood and I'll have to replace them with some sucky bias plie tires. I have replaced some of the body rubber nubs, otherwise it is in good shape. Even the electric windshield still works.
