Author Topic: Cracked frame at shock  (Read 63508 times)
Re: Cracked frame at shock
« Reply #100 on: April 07, 2019, 06:06:16 PM »
What's the p/n of the failed part MOB?  Answered above I now see.
the actual frame...
BUT....
one thing, and this is the kicker....
is seen in the photos... and cannot be hidden...
the dogbones used there are NOT the factory installed ones... those are aftermarket/home made/whatever....
I hold no credibility that it is on the fault of Kawasaki, of a frame fracture, resulting from a modified suspension "add on"... and for a fact, have always cautioned people about doing them...
semper fi.  caveate emptor....
« Reply #101 on: April 07, 2019, 06:15:52 PM »
here is the pic from the original issue... note the linkage...
http://www.zggtr.org/index.php?topic=23720.msg296413#msg296413
now that aid, I cannot say for certain, he had not swapped his out for one from another kawasaki model (zx, etc.,) even if it was an OEM, but from a different bike... but I know the last person reporting this '08 breakage does NOT have OEM parts.
« Reply #102 on: April 07, 2019, 06:30:13 PM »
Notice this crack, too.  Speculation, but I don't think that would happen in that location from just the frame cracking from fatigue.  It looks more like some type of severe bottoming-out hit?  That could be consistent with being overly-lowered?  Or maybe it is just secondary as the weight shifted and caused other damage.
« Reply #103 on: April 07, 2019, 06:37:26 PM »
actually, from my visual comparison, the ones on the failed bike appear to be significantly shorter than OEM, which would render the bike sitting higher... and during "decompression stroke" of the shock, would render a "slide hammer effect" upon that bracket... kinda as it is seen, being broken "away/down" by that force.
but I can't just go on "visual measurements"... I can however go on "visual deviation of/from OEM parts used"...
Offline JhVenezuela
  • Country: ve
« Reply #104 on: April 07, 2019, 07:12:35 PM »
Sorry again, but that is not a Crack.
Offline Michelle
  • Saving the chubby unicorns
« Reply #105 on: April 07, 2019, 09:35:27 PM »
Something must have severely stressed both of those bikes to break them.
My 2008 took a leap across a four metre ditch and the landing went ... badly. I've since put almost 100K kilometres on it and there is no cracking in the frame.
Notice this crack, too.  Speculation ...
That's a casting mark on the engine case.
Glitter White 2010 1400GTR
Windsor Green 1997 GTR1000
« Reply #106 on: April 08, 2019, 12:09:42 AM »
Ah- fooled me!
Yep.  Was the bike lowered, raised, or neither?  (Not that it necessarily led to damage, just curious now).
Offline JhVenezuela
  • Country: ve
« Reply #107 on: April 08, 2019, 06:37:04 AM »
Yes, the bike was rised (+30 MM) on 2011, using a Tail Raiser from www.bikefarmMV.de
IMO, That part is weak on that sensible area (hollow) .
Here in my country the roads are not as well as should be, most of the time during our trips we run at 200 - 240 Kms,
that is a lot of streess for that mechanism.
I did not mention this before, I close friend of mine , with a concours 2015 had the same problem last year.
As I said before,  That`s  a MAMA KAWA PROBLEM.
« Reply #108 on: April 08, 2019, 09:03:24 AM »
Throwing out idea's;
  No argument is intended. Just adding my thoughts about the failure.
I initially thought we had another "type" of failure on this bike, as "this time" the crack (we see in (Post 92) photo 1 & 2) was not on a weld line..  Looking more closely at the photo's I discovered there is a similarity between the 2 failures.
That similarity is a failure at the welds... (See MOB's post #84)
I think; the initial failure was on the left side (Photo 3) at the weld (in the heat effected zone). (photo 3)
             that failure allowed the right side to flex and the result was a (more typical) fatigue failure. (photo 1 &2)
            {NOTE: That (right side) crack probably initiated at the weld, but the majority of that crack is not in the weld area}
I'll agree that the replacement of OEM parts can cause problems and could have contributed to the problem by increasing force at the rocker.       I just don't think the aftermarket Link caused this problem.
I think the problem is the frame construction, not extra force caused by installing Lowering or Raising Links.
Explaining my thinking;  The rocker's arc has not changed.
                 The arc of the rocker is controlled by the shock length / shock travel, not by the length of the Link.
                   ie; The rocker cannot travel more or less than the shock length / shock travel will allow.
                  Installing longer or shorter "Links" will effect the arc of the swingarm, not the arc of the rocker..
                   ie; The new Links effected the swingarm. Rocker was operating in it's normal travel range.
 The frame is designed to haul a loaded bike or 2 people for 100,000 miles.
    1 person on a rough road should not cause a frame failure in 28,000 miles.
Bottom line; The frame flexed/failed and it should not have... {even with the after market Links).
« Last Edit: April 08, 2019, 05:00:18 PM by connie_rider »
« Reply #109 on: April 08, 2019, 03:26:51 PM »
sorry
anyone that tells me that this lays on Kawasaki, needs their head examined...
using this?
https://www.bikefarmmv.com/epages/79512538.sf/en_GB/?ObjectPath=/Shops/79512538/Products/%22HHLRKA%20GTR%201400%20%2007-%22
better study a bit more about Tetra Link geometry, and understand about how fast forces can exponentially multiply when "simple" dimensional modifications are applied "by a lever", that they were not engineered for....
I still cannot explain the failure on the original '08 that started this whole thread back in time, but I wish some one "good luck" trying to pass this one off to Kaw, with those modified linkages.
Offline JhVenezuela
  • Country: ve
« Reply #110 on: April 08, 2019, 04:24:11 PM »
This is as true today as  affirm  that "Concours Do not drop off the baggages !!!!!
During all these years i have seen several concours baggages  rolling around the roads, except mine and you know why ?????
Because I modified it !!!!!!
Come onnnnnn
Don't you rememenber the kawasaki recall (2008) about  Replacement rear carrier platform !!!!!!
it break !!!!!!!!
Not mine and you khow  why ???????????    Because I modified it, before Kawasaki recall
What about the oil plug carter position, I replace mine with 2009 model, Ohhhh my goood, coud  i damage the engine !!!!!!!
I'm not a beginners and I haved installed in at least half dozen motorcycle, tail raiser, replace rear shock  without any problem as many people do !!!!!!!
That is not the problem !!!!
You can bet !!!!!
« Last Edit: April 08, 2019, 05:22:48 PM by JhVenezuela »
« Reply #111 on: April 08, 2019, 05:09:04 PM »
JhVenezuela, did your friends 2015 also have tail raiser Links, or did it have stock links?
                    do you know ao any other bikes that have had this failure?
                    How tall are you and friend? {why did you raise the rear of the bike}
Offline JhVenezuela
  • Country: ve
« Reply #112 on: April 08, 2019, 05:16:12 PM »
No, he did not have raiser links on his bike.
I'm 6'4 and  230 pound.
Raising the bike i feel more confortable on it, specially my knesss.
my fried is arrond 5'8 or 6
Offline blue72beetle
« Reply #113 on: April 08, 2019, 05:22:53 PM »
Trailered on the centerstand?
Offline JhVenezuela
  • Country: ve
« Reply #114 on: April 08, 2019, 05:25:32 PM »
Nop. Never.
« Reply #115 on: April 08, 2019, 05:37:14 PM »
EDITED by request:
so, the original reported failure was here in USA, on a 2013, with no height modifications.
then, the second report is your 2008, with links to raise the bike. Located in Venezuela.
then, a friend of yours, again in Venezuela, with a 2015, and no height mods, has had the same failure, relayed to us.
(which seems very strange, to have 2 failures, on bikes from people that actually know each other).
What was the outcome/and follow up, with regards to your friend's bike getting repaired, as I would assume Kawasaki was contacted by him, being such a new bike?
the original reported bike was completely repaired by Kawasaki.
I suggest you, and your friend, contact Kawasaki, and fully report your issues..
and have them discuss it with you. Without owners reporting issues like this directly to them, there is little Kawasaki can or will do with regards to any of this. We cannot do it for you.
I apologize for appearing rude with regard to your report.
best of luck.
« Last Edit: April 09, 2019, 12:54:55 PM by MAN OF BLUES »
Online zrx mitch
« Reply #116 on: April 08, 2019, 06:39:46 PM »
 :popcorn:
IBA #18591
Offline JhVenezuela
  • Country: ve
« Reply #117 on: April 09, 2019, 10:14:48 AM »
Another tip !!!!!!
I did not mention this before, but i have 2 Concours 14, 2008
The other one, a gray one, have 45K Miles with the same "Tail  raiser" and
another Shock (Ohlins)   since 2001 installed, the frame is in perfect condition,
maybe require an expert inspection.
After alll, i'm just a simple "ENGINEER", not a "GURU" !!!!!!!!!
But thinking about this problem, I have a final conclusion.
I was wrong, the problem is not because a "Inconsistent Frame", the real
cause in the Color !!!!!!
Both bikes are GREEN !!!!!
How could not seen these before,  My fiend have a 2015 Lime green and I
painted the bike on 2014.
Incredible or not ????
Enjoy the day !!!!!
« Reply #118 on: April 09, 2019, 11:53:54 AM »
Jh, I think you figured it out. Definitely the color.
MOB convinced me that the Tail Raiser adds stress to the frame, but I still think there is a problem with the weld area too.
I suspect it's borderline on strength; then add Tail raiser, rough roads, rider weight, speed etc,,, and it failed.
I'll also agree that Kawasaki wouldn't help you if they saw the tail Raisers installed.
Because; {regardless of them causing or not causing the issue} Kawasaki (or any Dealer) would say that was what caused the failure.
I haven't heard of anyone in COG installing Tail Raisers, but many install a taller rear tire.
So, when you get another frame, consider installing a 190-55 tire instead of the stock 190-50 tire {as it raises the rear a bit} and see if that "bit" is enough rise for you.
PS: Another question. How much preload is dialed into your rear shock spring?
                                 Have you set the sag?
Offline JhVenezuela
  • Country: ve
« Reply #119 on: April 09, 2019, 12:51:49 PM »
As i listened in tv series .... "everything he says will be used against him"
I'm using now a 190-55 Pirelli
About the rear shock  setting, I usually use a Hard adjustment on it, because is better at high speed
I'm using now a Pirelli 190-55
