Author Topic: '08 C14 glove box revisited  (Read 16481 times)
Excavator
Re: '08 C14 glove box revisited
« Reply #20 on: July 06, 2011, 08:20:17 PM »
The GB will hold and extra pair of underwear, which if you ride a black one you might need from time to time...  :o   ;)
 :rotflmao:  And don't forget the pilot's license.   :thumbs:
Offline marku8a
« Reply #21 on: July 06, 2011, 09:22:25 PM »
Not sure if others has this problem. My box lid would not open with just pressing the release button. I had to push the lid toward me to get it to release. I took it off and found the problem. A little filing and bingo! Now fixed and working like it was supposed to in the first place!!
2009 C14 Red
« Reply #22 on: July 06, 2011, 10:22:28 PM »
I added a pre-2010 glove box to my 2010.  I would not give it up - I use it for quite a few things.  BTW, no it's not a straight forward bolt on.  Some fabrication was involved but for a good do-it-yourselfer with some imagination it still less than a two hour job.  A "how to" thread was lost in the May forunami.
Maybe the OP and jjsC6 could ping each other and see if a swap could occur, a coupla$$ for a panel?  Just a thought.
Offline bob14
  • go forth and meet the shadowy future without fear
« Reply #23 on: July 07, 2011, 05:29:52 AM »
GLOVE BOX ???????
Oh you mean the power panel
2008 C14
COG 8211
AMA 848986
Some people try to turn back their odometers. Not me, I want people to know "why" I look this way. I've traveled a long way and some of the roads weren't paved.
« Reply #24 on: July 07, 2011, 05:55:05 AM »
Mine does the same thing. I haven't gotten fed up enough yet to pull it apart and fix it, soon though. What did you file?
Offline Y0ssarian
« Reply #25 on: July 07, 2011, 06:41:28 AM »
GLOVE BOX ??? ??? ?
So you took the only storage space that can be accessed while underway, and filled it with things you don't need to access while you're underway?
