Author Topic: Center stand  (Read 3694 times)
Offline paulthibodeaux
Center stand
« on: August 30, 2018, 03:55:57 AM »
Not as strong as I was. Need help putting bike on center stand. Can I cut an inch off the stand?
Offline Rubber_Snake
  • 2009 GTR1400 ABS, Black
Re: Center stand
« Reply #1 on: August 30, 2018, 07:24:53 AM »
I used to have a tough time with the center stand too.  Possible it’s your technique?
https://youtu.be/astp0sJSrWQ
This guy is probably about 220 lbs.  What do you weigh?
Re: Center stand
« Reply #2 on: August 30, 2018, 10:15:53 AM »
I had no problem when I had a 1400, but the 1000 is giving me fits.
Re: Center stand
« Reply #3 on: August 30, 2018, 01:52:15 PM »
I think they require different techniques. I had trouble with the 14 at first.
Re: Center stand
« Reply #4 on: August 30, 2018, 04:35:52 PM »
Had a Yamaha FJR and it was a piece of cake.
I can gat it on the center stand, but it is hard.
May cut a half inch off.
Re: Center stand
« Reply #5 on: August 30, 2018, 04:56:54 PM »
personally, I wouldn't... makes getting the tire off a p.i.t.a.
simple fix, free basically, just find a piece of 1x4, or 2x4 10" long, and roll the rear tire up on it... easy, free, and it will fit in a side bag.
Re: Center stand
« Reply #6 on: August 30, 2018, 07:48:18 PM »
... or maybe just a 1x4 which would gain 3/4" at the rear tire, a little less at the centerstand itself, and you could cut the ends on a 45 to roll up on it like butta.
Re: Center stand
« Reply #7 on: August 31, 2018, 03:21:27 AM »
The 1x4  sounds like the way to go. Thanks guys.
Offline buzzcut
Re: Center stand
« Reply #8 on: August 31, 2018, 09:44:33 PM »
you could put the front wheel up on a 2x4 which gives the height to easily put on centre stand.  It is what I have done and works well
Offline Eupher
  • U.S. Army, Retired
Re: Center stand
« Reply #9 on: September 01, 2018, 01:04:55 AM »
Yep. I put on lowering links and that made the center stand impossible to employ. The 2x4 trick works pretty well.
2012 C14 Arabian Candy Red
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
Re: Center stand
« Reply #10 on: September 02, 2018, 03:51:38 PM »
Really?
did you try it under the rear tire only? beforehand?
Offline buzzcut
Re: Center stand
« Reply #11 on: September 02, 2018, 11:59:13 PM »
Never did try it under the rear.  Years ago before the site crashed someone said under the front and it worked well for me so I did not even consider to try the rear.
Offline Furbo
  • Country: it
Re: Center stand
« Reply #12 on: September 15, 2018, 06:05:10 AM »
Ensure you have enough air in the rear shock and that the 'sag' is properly set.
Tire choice makes a huge difference!
It's never 'easy', but it can get better.
05 C-10
Eccl: 9: 7-10
Offline Mettler1
Re: Center stand
« Reply #13 on: September 15, 2018, 08:40:19 AM »
  I drive the rear tire on to a 2 x 6. Put down the side stand and dismount. Put my foot on the center and lift with the grab handle up and back. Takes a little muscle. Works even better if some one pulls the bike back.
Re: Center stand
« Reply #14 on: December 17, 2018, 05:03:43 PM »
Re: Center stand
« Reply #15 on: December 17, 2018, 05:43:57 PM »
Would this help?
http://www.1cruiser.com/sa/cart/detail.asp?pg=%7BF41B52F9-4175-4E9C-8054-E32EFA2879FF%7D
I think I actually had that on my C10.
Indeed it will assist greatly, allowing a much better hand position for the lift...
it also is a great place to lock a helmet, and or jacket and gear, running a cable lock thru sleeves or face opening on helmet. Nice piece of metal.
