Author Topic: Removing battery - where did this little guy come from?  (Read 21890 times)
Re: Removing battery - where did this little guy come from?
« Reply #20 on: July 04, 2018, 09:40:49 AM »
You coulda just bought him a beer  :chugbeer:  ;)
Oh, I forgot about that one.
« Reply #21 on: July 05, 2018, 07:01:19 AM »
Does that mean I don't get the hug?
« Reply #22 on: July 05, 2018, 07:51:31 AM »
You get a hug from a beer.
« Reply #23 on: July 05, 2018, 09:39:39 AM »
Maybe you two to should just get a room, for whatever you finally decide on.
Well once again, I'm confused. Regardless of Gen I or II there are only two grommets like that on the whole bike. (according to the parts fiche )
The OP's bike is an '09 so it does have the bracket that the Gen IIs do not, but earlier he said that..
Thanks, jwh20. Unfortunately those 2 pieces are accounted for.
...so maybe a PO lost one in there and replaced it and when mexico pulled the battery he found the original one?
I think jwh should get the credit and the hug with a couple of points off for showing a link to a Gen II fiche when answering a question about a Gen I bike...
..but that's OK, I think I can speak for jwh and say you two just continue on with whatever without him.  ::)
Offline sanmo
« Reply #24 on: July 05, 2018, 01:41:00 PM »
........but that's OK, I think I can speak for jwh and say you two just continue on with whatever without him.  ::)
Pro boner advice from Monsieur Marty?
2008 Silverdammit C14
« Reply #25 on: July 05, 2018, 05:02:06 PM »
There are also two more at the top of each fairing, left and right. Not sure if they are the same size but they <look> the same. At least on the Gen. 1 C-14's, I cannot speak for the second generation fairings as I have not removed all that many (probably because I run whenever I see a '10 or later come into the garage that needs to have its clothes removed).
The OP's bike is an '09 so it does have the bracket that the Gen IIs do not, but earlier he said that.. ...so maybe a PO lost one in there and replaced it and when mexico pulled the battery he found the original one?
« Reply #26 on: July 06, 2018, 10:51:21 AM »
I just found 3 more grommets in the air filter fiche all with different part numbers, could be one of those.
92071-1042
92071-1259
92071-2140
It seems there are a lot grommets and grommet looking things called dampers in the fiche, I think the grommets have more rounded outer edges
and the dampers have a more squared off outer edge but unless I were to look at every one on my bike I couldn't be sure about that. I just don't care that much.
I think I know the ones Brian is referring to (92160-1613) but I think those are the more squared off dampers, there are also two more (same part number) used at the rear of the bike
where the rear turn signal housing attaches to the sub frame.
(...... I run whenever I see a '10 or later come into the garage that needs to have its clothes removed).
Becoming a bit prudish in your advancing years, eh?  ;D
Offline kzz1king
« Reply #27 on: July 06, 2018, 11:05:53 AM »
If you guys want to do some more searching I have a zip lock full of stuff from my valve adjustment I could not find a home for. :D
Wayne
2010 CONCOURS
1974 Z-1
« Reply #28 on: July 06, 2018, 04:32:47 PM »
Nah, just never warmed up to the Gen. 2 tupperware. Nor the glovebox, the lack of the original, center glovebox or the heated grips for that matter. I also prefer the looks of a Gen. 1. But in the end, I really do not like having to futz all the rubber into / around / between the fairing and engine, transmission and frame parts on the Gen. 2. So I tend to avoid it, and that prevents me from getting better at R&R'ing it and so it is a vicious circle. Soon enough though, I expect to be forced to deal with one of those, specifically a '16 (I like the color) if I can find one at the right place and price.
My new, shiny granddaughter is coming home tomorrow (crossed fingers) and I have nothing to ride south to meet her. :-(
<snip>
« Reply #29 on: July 06, 2018, 07:34:26 PM »
I can understand perhaps not liking the switch from the center box to the auto-locking side box.  But what is not to like about adjustable grip heaters?
Not me.  I think the Gen 2 looks a LOT better.  But, of course, that is subjective.
Yes, the Gen 2 does have more heat control stuff under it.... some rubbery stuff and separators.  It is a bit annoying, but it does serve a really good purpose.  Add the Canyons and it is quite the task to get some of the fairings off.
