« Reply #4 on: November 30, 2017, 05:37:02 PM »
I believe a KTRC error is when the traction system senses a differential between the front and rear wheels. Because the sensors are the ABS wheel disc sensing system, you may well be right about oil causing a problem but I sort of doubt it because it is an induction system and should be impervious to oil; exactly how the cam and crank position sensors work perfectly in an oil- bathed environment. Any chance it happened during acceleration? If so, maybe the rear wheel broke traction slightly and turned a but more than the front wheel; it does not take much of a difference to trip the ABS or traction control systems.
That is a good troubleshooting question. I have had numerous isolated F1 errors, and they were always while just riding- no acceleration, no braking, no engine stutter, nothing. I can't recall what it says on the screen other than "F1" because it is always while moving and disappears very quickly. Curious- is there something on the screen that actually says "KTRC" or something else before the F1 appears?
Logged
