Author Topic: Rear drive oil LS?  (Read 2058 times)
Offline ruffride
Rear drive oil LS?
« on: August 27, 2017, 04:49:24 PM »
Sorry for an oil thread. Is a LS (Limited slip } rear drive oil bad for the C-14 drive????
Thank you in advance.
« Last Edit: August 28, 2017, 06:19:27 PM by ruffride »
Enjoy the ride
Re: Read drive oil LS?
« Reply #1 on: August 27, 2017, 06:09:01 PM »
You catch on quickly!  :)  I can't answer your question, but I can say:
Oil thread!!!
Offline jwh20
« Reply #2 on: August 27, 2017, 07:12:21 PM »
Look for the designation GL-5.  If it has that, then you are good.
« Reply #3 on: August 27, 2017, 08:36:37 PM »
Sorry for an oil thread. Is a LS (Limited slip } rear drive oil bad for the C-14 drive? ???
You should be ok with it but I haven't stayed in a Holiday Inn Express lately.
Offline ruffride
Re: Rear drive oil LS?
« Reply #4 on: August 28, 2017, 06:27:55 PM »
Mobil 1 Syn Gear Lube LS 75W-140 meets or exceeds the requirements of the following industry specifications: API GL-5
So it claims to:
Meet or exceed the highest level of performance requirements of many modern passenger vehicles – including limited slip applications.
It seems this would be fine just though I would ask the collective.
Best,  Jon
Enjoy the ride
« Reply #5 on: August 28, 2017, 07:59:19 PM »
75w-140??   140 seems a bit thick.  I've been using the 75w-90 for 10 years without any issues at all.
Offline ruffride
« Reply #6 on: September 07, 2017, 09:51:53 AM »
115 degrees out here at times... Just for the summer then I will switch to 75-90 or that was my plan.
Enjoy the ride
« Reply #7 on: September 07, 2017, 11:28:23 AM »
Manual says 90w above 41F.  I really think 140 is a bit thick but that's up to you.
