Author Topic: Howling noise at 75-80 mph (not wind) '09 ABS with 39k miles running synthetic  (Read 11055 times)
Thanks Max.  I DID install a solid state flasher and put LEDs in the rear signals.  In fact, today, I just installed the switchback dry/turnsignal lights in the front.  Gonna convert the rears to tail/brake/signals next...
I think it has something to do with leakback through ground.  I just know it is scary as hell when it happens, and doesn't look like it can be good for the bike.
Offline jonathan
That happens with certain electrical add-on accessories, like LED lighting on the turn signals.  On mine, it will go crazy if I have any flasher operating (or maybe just the emergency flashers) when the ignition is turned off.
It happens with both the 4-ways and the turn signal. I just got in the habit of turning them off before the ignition. Kind of like a shutdown checklist.
Offline rcannon409
I tried to run a signal cancel device. The Kisan unit. The company would not stand behind a defective unit...
  It actually worked, for about 15 minutes, but thats not even the point....
When I installed it, I turned my bike to the start position, and the electronic system freaked out. I had flashing, beeping, completely out of control.
I came back in and googled the issue.  Someone had made  a post, from years earlier, and mentioned pulling the KIPASS talk back fuse.  I pulled this fuse, and everything was normal again. That thread is right here:
http://www.zggtr.org/index.php?topic=5174.15
Offline AZ-ZG
Sorry for the delay. I blame Irma as I now have electricity again.   :o
Rubber_Snake I asked if it was a new noise because mine has had a gear whine noise since day one.
Me, 2009 ABS with 122,000 miles.   :)
I hear it when cruising, steady throttle, at 75 to 80.  Full face helmet and ear plugs.
Seems to come from the output shaft area just in front of my left ankle.
The rare times without earplugs riding, think grocery store to gas station, first gear has a good "spooling up" sound.
I wouldn't worry about it unless it bothers you. IMO    8)
Others may say pull the final drive and moly paste the :censored: out of everything.
Winter is coming if you need a project.   :chugbeer:
I live. I ride. I am. ZG14
IBA#53928
Offline Rubber_Snake
  • 2009 GTR1400 ABS, Black
You know, you might be right about this.  I'm thinking that I will pull the final drive and moly paste the  :censored: out of it!  I can't find the Honda 60 stuff online.  I think they do not produce it anymore.  Is the Honda M-77 a good replacement?
« Last Edit: September 18, 2017, 10:37:01 AM by Rubber_Snake »
Any moly paste with at least 50% solid content will work; the newer Honda stuff is fine but expensive. The old Honda moly paste was the bargain of the century but it is no longer available.
There are other sources as well, such as Loctite, which are also fine to use.
You know, you might be right about this.  I'm thinking that I will pull the final drive and moly past the  :censored: out of it!  I can't find the Honda 60 stuff online.  I think they do not produce it anymore.  Is the Honda M-77 a good replacement?
Offline rcannon409
I'll bet that newer Honda stuff would be fine, but if I were making a special order to get it, I would order this, instead...why not use the best after all the labor involved?  The dow corning 77 was VERY similar to the old Honda stuff.
http://www.ebay.com/itm/DOW-CORNING-MOLYKOTE-M77-Paste-Grease-Lubricant-Lube-oz-Silicone-Oil-Moly-MoS2-/281006528716
Notice how small the container is. Maybe get two of them?
