Feeling good. I finally got my bike back together and took it out for a short drive on Sunday to verify all was working. I did have a little coolant leak so I tightened it down, wait for the engine to cool and refill it. The second time there were no leaks.
So I have rebuilt carbs and synced them, oil and filter change, coolant drain and fill, cleaned and oiled my air filter. I also cleaned my bike under all the plastic. I wasn't really sure how I wanted to tackle it so I did some reading. I ended up picking up a bottle of LA's Totally Awesome degreaser. Sprayed it all over, let it dwell for a minute then took a brush to it as it needed agitation after sitting like that for a long time. It's much better now.
I also topped off my gas tank and drove it to work on Monday. One of the things I still want to do is change my clutch oil. Maybe even my brake fluid. Eventually I will replace my brake lines with braided steel lines. The front is a split system with one line going to a splitter and into two lines. I want to change them to a straight two lines, one to each caliper.
I do still have the issue of my water temp. gauge not working. I thought the new sensor would work but no go. On Saturday I will test the gauge to see if it is busted.
