Author Topic: Re: ECU flashing now available  (Read 15198 times)
Offline sanmo
« Reply #20 on: June 26, 2017, 06:04:15 AM »
"sor e  bt it dosnt wrk that wa u wll hv 2  suppi ure own ecu"
I trust your Malay is impeccable before venturing a post in such poor taste. smh
2008 Silverdammit C14
Offline Bai65
« Reply #21 on: June 26, 2017, 07:00:18 AM »
Ok can u give the address to me then i check dhl n ups how long will it takes to send to steve 😁
« Reply #22 on: June 26, 2017, 07:17:59 AM »
http://sites.google.com/site/shoodabenengineering/home
Re: Re: ECU flashing now available
« Reply #23 on: June 26, 2017, 09:57:34 AM »
Sanmo, you have to forgive max', he doesn't get out much. He sits at home watching TV when he should be bleeding his brakes. The guilt builds up inside of him
until he lashes out with these little snipes of his to relieve the pressure build up.
« Reply #24 on: June 26, 2017, 03:36:53 PM »
What was posted was apparetly text message jargon :)   y for "why", u for "you", xtra for "extra", n for "in"... seemed deliberate to me.  I would never pick on someone's English, especially when non-native.  It was meant to be a funny reply back also in text message jargon.  And what I said was valid- it doesn't work that way, one would have to ship one's own ECU in for flashing.
Bai65, it if wasn't funny, I apologize (deleting it too).
« Reply #25 on: June 26, 2017, 10:44:52 PM »
What was posted was apparently text message jargon :)   y for "why", u for "you", xtra for "extra", n for "in"... seemed deliberate to me.
You actually know that stuff (txt jargon)? I'm impressed.
« Reply #26 on: June 27, 2017, 05:35:29 AM »
I like investigating foreign languages
Offline Hooligan
  • Country: za
  • never assume, get the facts
« Reply #27 on: June 27, 2017, 05:54:25 AM »
Sometimes things gets lost in translation though...... and more often that not, it is problematic.
2012 K1600GT
2009 ZX14
« Reply #28 on: June 27, 2017, 06:23:35 PM »
Here is a fun tool for those times:
http://transl8it.com/
"now is the time for all good men to come to the aid of their country"
"nw iz d tym 4 aL gud men 2 cum 2 d aid of thR cuntrE"
Viola!  Saved a whopping 12 characters while simultaneously being elite and super-cool cryptic!
« Reply #29 on: June 27, 2017, 06:35:06 PM »
<...while simultaneously being elite and super-cool cryptic!...>
"yrtunoc rieht fo pia eht ot emoc ot uem poog lla rof emit eht si wou"
« Reply #30 on: June 27, 2017, 06:46:54 PM »
You made some typos there....  :)
« Reply #31 on: June 27, 2017, 07:17:01 PM »
best I could do typing looking in the mirror... ::)
Offline Bai65
« Reply #32 on: June 28, 2017, 12:40:38 AM »
No probleam it just word i dont take it seriosly if u all not understand my english let me now i xplain in malay 😁i not so good in english because my school only teaching ni malay ya just forget it .about the flash ----if i flash the ecu n used the stock pipe its ok ? 2) if later after the flash n i change the aftermarket pipe should i reflasf again? And which pipe is good for c14 zg1400 2016?
« Reply #33 on: June 28, 2017, 05:43:25 AM »
Your choice of muffler barely affects flow/pressure, so it doesn't matter.  Pick any you like and it should work the same.  The only significant reason to change just the muffler is cosmetic/noise.
The one that comes with it works great.  :)
Offline Bai65
« Reply #34 on: June 28, 2017, 08:48:59 PM »
Ok thank u for info, n  how long do u all send tn get back the ecu  from steve  if 2 weeks should i disconneted the bet3 from the c14? 😁
« Reply #35 on: June 28, 2017, 09:05:39 PM »
That depends entirely on transit time (the carrier and options chosen for shipping).  I doubt Steve takes long on his part;  I believe the actual flashing of an ECU takes only a few minutes.
What is a "bet3"... a battery?  If yes, then I do recommend disconnecting the battery before removal or installation of the ECU.  Although others have said they didn't bother and had no problems,  I like to be extra safe :)
« Reply #36 on: June 29, 2017, 04:06:34 AM »
I believe that Steve's recommendation is to not disconnect the battery.  I did for mine and had a bit of an issue.   Don't remember what it was or how long it lasted.  It did clear itself out, though.
Offline Bai65
« Reply #37 on: June 29, 2017, 09:39:58 PM »
Thanks for info  be4 steve flash the ecu did he back up the stock bin files?  Me b i will sending my ecu on monday .i am worroy about my ecu without it c14 cannot start .i concent because i stay in singapore n i send the ecu at usa will it come back safely😁😁😁
Offline Bai65
« Reply #38 on: June 29, 2017, 09:58:46 PM »
IF the flash it good me b i will ask my friend who ride the C14  gtr to send to steve for flash the ecu 🤗
« Reply #39 on: June 30, 2017, 12:53:46 AM »
Your FEAM (Fuel Economy Assist Mode) map will be unchanged (for gen 2), so you can switch to that anytime.  No other "backup" is going to be useful/helpful.  Yep, I would be worried too about shipping my ECU so far, but it will be worth the risk :)
