Author Topic: Subframe Bracket broken (welds)  (Read 8652 times)
« on: January 28, 2017, 10:16:52 PM »
I noticed that my left saddlebag was bouncing and so I gave the MCE saddlebag guard a tug and it really moved up and down alot. I took everything off on that side and I can see that the subframe bracket welds all appear to be cracked. I'm not sure what is really holding it on as the crack seems to go all the way around both ends. It could have happened on one of the tip overs I've had or perhaps it was cumulative damage from the 3 occurrences on that side. Or perhaps it was the inadvertent dual-sport ride I went on last august in New Mexico, but what ever caused it, I need to do something to fix it. Obviously it needs to be re-welded, but I also think it needs to be reinforced somehow.
I have 3 questions:
1) anybody else have this happen?,
and 2) if so how did you fix it?
3) What is the best way to reinforce this so it is stronger, but still remains the weakest link if it again receives too much force applied? That is to say, I'd like to reinforce it, but I would rather have it break again rather than twist the tube of the subframe where it is attached.
Feel free to say don't go dual-sporting on a C14, but I've learned my lesson and I won't ever do that again. (It's a long story, but I sort of got sucked in by a gravel road that I was sure was going to get better..but it didn't.) or feel free to say don't drop it anymore, but that is apparently out of my control since I've been saying that to myself since the first time.
outside of bracket, rust lines show cracks
underside of bracket
I have an extended warranty, but I don't think it should be covered even if they were willing because I'm sure it was caused by a drop (or drops) and is more like collision damage than defective welds IMO. Another question, 4) do dealers do welding or do they simply replace the subframe?
Re: Subframe Bracket broken (welds)
« Reply #1 on: January 29, 2017, 06:21:13 AM »
Damn Marty, that's tough luck. I think I'd try to find a salvage frame and replace it. It's got to come off to repair and it'd would be nice to be able to bolt another right back on. Looks like a new one will be about a grand.
« Reply #2 on: January 29, 2017, 06:32:17 AM »
I have never seen a report on the forums of anything structural like that before.  The tube isn't all that large compared the the flange and large area that would need rewelding.  I would be worried that any type of repair would continue to leave the frame weakened and dangerous.  Best to ask someone who has specific expertise in this area.
Dual-sporting on a C14?  Ouch :)
« Last Edit: January 29, 2017, 07:46:34 AM by maxtog »
« Reply #3 on: January 29, 2017, 06:41:35 AM »
Proper repair would be as strong or stronger than oem.
Offline rrsperry
« Reply #4 on: January 29, 2017, 07:09:38 AM »
Yep, grind it out, weld it up, spray some paint..
COntact a local welder, or welding company. You can call a local motorcycle shop and ask if they have any recommendations., If you were near me, I'd do it for you...
No matter where you go, there you are...
« Reply #5 on: January 29, 2017, 07:27:24 AM »
« Reply #7 on: January 29, 2017, 07:49:26 AM »
I agree, but I was implying that the typical home body who happens to have a Northern Tool welder (or whatnot) isn't necessarily going to be able to make a good repair.  And I am not saying Marty can't do it, I have no idea what his level of expertise and experience is with welding and structural repair  I have enough exposure to such things to know that improper repairs can be much, much weaker than the original structure  and could be very dangerous, depending on the location and what the frame is supporting.
Safety first!
« Reply #8 on: January 29, 2017, 07:51:40 AM »
Here you go.....
http://www.ebay.com/itm/08-10-KAWASAKI-CONCOURS-14-REAR-SUBFRAME-BACK-SUB-FRAME-OEM-/282047280152?fits=Model%3AConcours+14&hash=item41ab53f418:g:3~4AAOSwSWJXQ4Rd&vxp=mtr
Wow- $46!  That is a good find.  I can just imagine how much work it would be to install that sucker, though.  Makes my head hurt.
« Reply #9 on: January 29, 2017, 08:10:21 AM »
Looks like the cracked welds are failed oem robot welds. A skilled welder would make some nice dirt dauber nest welds like the one just above the rear crack in the first pic and it would be much stronger than oem. That's what the coonass welders around hear call them :D
I have not had the seat cover off and don't really know what I am looking at in the pictures but I assume from your description that it is the attachment point for the front upper saddlebag loop.
Did you have the MCE guard mounted when your 3 tipovers occurred?
« Reply #10 on: January 29, 2017, 08:42:30 AM »
Good question.
« Reply #11 on: January 29, 2017, 09:08:23 AM »
Looking at those photos, it looks like the tubing itself is cracked; one of the photos that shows two welds, top and bottom, also shows the crack extends beyond the weld itself which again means it is the tube under the weld area cracking, not the weld itself. If that is the case, I would strongly recommend a new sub- frame. Seeing as Gary found one for $46, I cannot imagine it would be worth trying to repair it anyway.
It is <possible> that this is not entirely uncommon on C-14's so just for chuckles, I would carefully inspect the new sub- frame for any signs of cracking before installing it.
A bad event but good that you found it the easiest possible way, and best of luck getting it repaired.
I have 3 questions:
« Reply #12 on: January 29, 2017, 11:18:26 AM »
Here you go.....
THANKS! gpink...ordered!
..anyway to answer some questions..yes the MCE saddlebag guards were installed before any drops. The front protection are Top Blocks.  All the drops were 0-.1 mph forward speed. The broken bracket is the only attach point on that side and it holds the rear shock preload adjuster, rear passenger footpeg and the lower saddlebag guide/holder, the MCE guard and my cup holder. The other side was only laid down twice, once on a soft grassy hill next to a driveway and once on a gravelly paved road shoulder when I was making a slow right turn and the TC killed the engine when i got some wheel spin. My foot went down to hold her up but just found air until it was too far over for me to hold it up. Yes, I'm one of those C14 owners that MOB would say should have bought a smaller bike, or at least a lower one. To which I say..
I have absolutely no welding experience at all, but I was starting to work on the situation with Instuctables classes and the anticipated purchase of a used MIG welder or a new HF one just for learning. From what little I know (or think I do) I think removing the subframe and TIG welding would be the way to go for repair...but like I said I don't really know..just a guess. It could be that a good MIG welder could make adequate repairs right on the bike if the rear wheel was removed. Like I said, I don't know that's why I came here to ask the question. Replacing the subframe does seem like a project for sure, I wonder what improvements I can make while I have it all apart.  ???
Thanks Brian, I will be inspecting the subframe and trying to have it reinforced as well, might as well repair the old one while/when it is off.
« Reply #13 on: January 29, 2017, 11:28:43 AM »
Excellent! It's just parts replacement now. Even a caveman could do it.
« Reply #14 on: January 29, 2017, 11:48:43 AM »
LOL- count me out!  I am glad he found a path to a solution, though.
« Reply #15 on: January 29, 2017, 11:51:13 AM »
Yay!
As one of those people, too, I join your sentiment :)
[...] I will be inspecting the subframe and trying to have it reinforced as well, might as well repair the old one while/when it is off.
Make sure to post info and photos of your ordeal, it sounds challenging/interesting
« Reply #16 on: January 29, 2017, 12:30:04 PM »
Not so fast, upon checking the Kawasaki online parts fiche there appear to be several part numbers for the subframe: 32160-0294-18R (2008 &2009); 32160-0472 (2010);  32160-0704 (substitute part on Ron Ayers for 2010-2014) Just for fun I looked up the 2015 subframe and it is quite clear that they beefed up that part, the front weld is longer as the front part of the bracket is longer ...that is the slot between welds is much shorter. It appears I'm getting one from a 2008 model. It also appears that the preload adjuster mounts differently between Gen I and Gen II. Regardless, before I put it on, it will more resemble the 2015 version.  It seems that there may be more relatively unseen subtle changes than we thought for the Gen I, Gen II and 2015+ GEN 2.1 versions of the C14.
« Reply #17 on: January 29, 2017, 12:52:48 PM »
Looking at the rest of the salvage from the seller I'm thinking their parting a 2010. I could be wrong.
« Reply #18 on: January 29, 2017, 12:59:32 PM »
That is exactly why I mentioned that your specific problem may not be all that isolated after all..... there could be a lot of C-14's out there with cracks in that structure.
I would be careful about "improving" a tube- weldment such as this one. We do not know what steel(s) were used, and we certainly do not know the welding materials or process used (other than it was almost certainly short- arc MIG). Adding a weld to these materials may well be risky and not prove to be an improvement.
The cracks you showed (Easy Boys) appear to be classic structural welds over thin parent metals failures. The failure is not the weld itself; if it were, the crack would be down the center of the weld. The failure, at least as it appears to me from those photos, is actually the parent metal (the tubing itself) fracturing along the edge of the weld in what is called the HAZ (heat affected zone). Believe it or not, this is the most crucial part of any structural weld assuming normal welding failures, such as hydrogen embrittlement, have been eliminated in the first place by the welding process. What you are seeing is the tubing failing because all of the stress from the mounting plates is concentrated along an extremely narrow space due to being confined by the weld itself. In other words, the tubing AND the weld bead cannot move because they are too rigid (Boys!) so all flexure must happen at the edge of the weld(s). A classic failure- just ask Honda :-)
Again, my suggestion would be to buy another sub- frame and inspect it carefully and then just use it as stock. If you really feel you must reinforce the weldment, I would suggest putting small plates over the weld beads so that the new welds do not touch the original welds at all.
I am not faulting your thinking here Marty, just saying that I think this is one of those situations where making it 'better' will make it worse. Sort of like adding a whole lot of reinforcing steel to the deck of a suspension bridge to stiffen it (Easy!) only to find out that in doing so the cables and cable anchor points have now been overloaded with dead weight. The deck will absolutely be stronger but it may then rest on the bottom of the water it used to span....
« Reply #19 on: January 29, 2017, 01:29:11 PM »
Thanks Brian. So you think filling the gap between welds with more steel would be bad?  It would no doubt have the same problem as the current welds but there would be more of it at least perhaps with small air gaps at each end so as not to touch either current weld ( they would probably get thermally touched). The only other thing I can think of is a slight triangulation piece from the back of the tube to the bottom of the bracket.  :-\
