Author Topic: Want to buy a strong rear rack for GIVI 46L monokey trunk  (Read 3178 times)
Offline Silverbullet65
« on: December 29, 2016, 06:46:20 PM »
I have a GIVI 46 storage trunk with the plastic mount but I want a used aftermarket aluminum
Plate the the GIVI can mount straight on.
Thanks
Safety is no accident
Re: Want to buy a strong rear rack for GIVI 46L monokey trunk
« Reply #1 on: December 30, 2016, 08:36:46 AM »
Try contacting the Wizard on the COG Forum.
I suspect he has one or knows where to get a used
one.
« Last Edit: December 30, 2016, 11:16:06 AM by connie_rider »
Offline ljcorby
  • COG#: 9359
« Reply #2 on: December 30, 2016, 09:21:43 AM »
Try Phil's farkels....great rack and works like a charm.
http://www.philsfarkels.com/
10 Kawi Concours 14 ABS
Offline tonedeaf1
« Reply #3 on: December 30, 2016, 07:27:36 PM »
I don't believe you can get one any better.
Offline HaChayalBoded
« Reply #4 on: February 01, 2017, 07:29:58 PM »
The plastic one is stronger than the aluminum one. Aluminum cracks under a Connies vibrations while the plastic one will not.
That "plastic" rack has held 100lbs steel components in a GIVI case running around Brooklyn cobblestone streets just fine. I have never had one fail.
Go ahead and use it, no need to go out of your way for an aluminum plate.
Also, the aluminum plate does not bolt onto the base mount of the GIVI rack setup.
PS I had a few broken GIVI aluminum plates in the past.
Offline O.C.
« Reply #5 on: February 03, 2017, 02:40:12 AM »
 :goodpost:
CARPE DIEM
KAWASAKI VERSYS 650
Offline ljcorby
  • COG#: 9359
« Reply #6 on: August 28, 2017, 03:07:18 PM »
As far as I know, Phil's alluminum plate has never and will never crack with a Givi trunk attached to it.  Much stronger than the plastic rack that came on my new 2010.  Just sayin.
Offline Paulmc
« Reply #7 on: August 30, 2017, 06:54:59 PM »
I have a Phil's rack with the mounting hardware in the sale section if your interested.
Offline tonedeaf1
« Reply #8 on: August 30, 2017, 08:58:05 PM »
Ditto on the Phil's rack. I bolted a back rest to one. On long trips I strap a tall tail trunk to the rack and my wife rests happily on the backrest. It has been in place for over five years.
